03-29-2016, 02:08 PM
(This post was last modified: 03-29-2016 02:57 PM by bakonick.)
Post: #131
(03-29-2016 11:35 AM)totta Crolla Wrote:It will be only for race use . The material is polyethylene is the same material that all modern car fuel tank use . Yes it can handle all kind of fuels.(03-29-2016 09:33 AM)Ivan141 Wrote: Interesting, but I'm concerned about safety when it's hanging below the car without any protection. I will also build a round one for the spare well . and a swirl pot 2 liter . The plastic is more flexible and durable compare with the steel tanks. 1976 TA28 CELICA 1978 PUBLICA PICKUP 1980 4WD PICKUP 1983 AE86 LEVIN 2007 AYGO |
06-10-2016, 11:09 PM
Post: #132
(03-28-2016 08:07 PM)bakonick Wrote: Hello after some time im back . Do you still make these? |
06-25-2016, 01:54 PM
(This post was last modified: 06-25-2016 02:00 PM by bakonick.)
Post: #133
(06-10-2016 11:09 PM)krullibull Wrote:(03-28-2016 08:07 PM)bakonick Wrote: Hello after some time im back . Its almost done in 30 days will be full production with photos and instalation photos. Here is my big brake upgrade that i made my self . 6pot calipers and 300x32mm discs from wilwood . i custom made the disc hats and the caliper adaptors. and i found that i can fit also 305mm discs with the 6pot calipers and with the smaller 4pot calipers it can take up to 310mm discs to 15inch wheels. 1976 TA28 CELICA 1978 PUBLICA PICKUP 1980 4WD PICKUP 1983 AE86 LEVIN 2007 AYGO |
11-21-2016, 05:58 PM
Post: #134
Hi i want to share my first ever race in circouit with my ae86 .
I start from last place becose i dint qualify . At qualify season i brake the throtle cable . I finished second place over all and second in 2 liters class. if you see the silvia brake down and for about 2 laps oil and water was all over at the tarmac . that was a reason for my exit after some laps . the video missing the last 5 laps full card and stop recordin. At list i get all the good action at first laps . https://www.youtube.com/watch?v=i45_dm_3NlM 1976 TA28 CELICA 1978 PUBLICA PICKUP 1980 4WD PICKUP 1983 AE86 LEVIN 2007 AYGO |
11-21-2016, 06:21 PM
Post: #135
Nice one!
Handled pretty much everything you did on it! Cool to see the shifting on the gearbox... The ratios are so damn different... Nice balance..... |
10-09-2017, 01:49 AM
(This post was last modified: 10-09-2017 08:43 AM by banpei.)
Post: #136
10-09-2017, 08:44 AM
Post: #137
Wow that engine sounds so sweet!
I've fixed the Youtube links to become videos. I still need to find a way to make the forum software to do it automatically... 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
09-24-2019, 01:21 PM
(This post was last modified: 09-24-2019 09:30 PM by banpei.)
Post: #138
Hi here is footage from local hill climb event .
from drone and onboard video Thanks Enjoy 1976 TA28 CELICA 1978 PUBLICA PICKUP 1980 4WD PICKUP 1983 AE86 LEVIN 2007 AYGO |
09-25-2019, 09:11 AM
Post: #139
Cool footage from that drone, would have been even better with sound. Looks like a fun road too.
12-02-2021, 09:51 PM
Post: #140
Hi Guys Long time to post and did a lot of work on the car .
full engine rebuild with Toda pistons rods and camshafts . port and polish head with bigger ferrea valves. elite 6 speed sequential gearbox and lightweigt flywheel 3.7 kg with 184mm tilton twin clutch. oem axle with custom 28mm shafts and lsd from elite racing. maxxecu and new loom 50mm itbs and face feed injectors. 4to2to1 exhaust manifold to 63mm exhaust . here is my first tests at the track. i am more than happy with the results. i made 280bhp at 8800 rev limit is at 9950 and the power there is 273bhp the car is a rocket . check my 3 videos https://www.youtube.com/watch?v=i2mBKNFvOLI 1976 TA28 CELICA 1978 PUBLICA PICKUP 1980 4WD PICKUP 1983 AE86 LEVIN 2007 AYGO |
Racecar: TRD USA built ITA AE86 | oldeskewltoy | 38 | 42,414 |
07-22-2019 02:55 PM Last Post: apardal |
Krullibulls Ae86 BEAMS is the only way | krullibull | 86 | 88,386 |
Aram's 3SGE Beams Levin Coupe | robokill | 665 | 727,716 |
AE86 GTV-Multipoint Cage, Beams, AP Brakes & Brides | Conrad | 462 | 604,330 |
S.K.s AE86 racecar | S.K. | 207 | 221,183 |
09-18-2016 11:39 AM Last Post: totta Crolla |
