ae86 running like shit HELP
04-18-2007, 03:57 PM
its only running on two clynders because when you take out plugs 1 and 4 the exhaust dosnt change its note.did compression test and that was perfect.put a new rotor arm and cap on still no change.so i put brand new leads and plugs and its still doing it.
whats next?
04-18-2007, 04:29 PM
tezza Wrote:whats next?
Igniter maybe...
Toyota scrap yard car park = AE92GTi - AE82GT - KE30 - KP62
04-18-2007, 06:33 PM
ye i was thinking the Igniter i will get a new one and see. Thumbs up!
04-18-2007, 06:51 PM
Igniter could be the cause, but you said:
Quote:its only running on two clynders
This tells me that you have spark on the other two cylinders, correct? Because you have a spark, doesnt matter if it is in only one cylinder, it spaks. Try another spark cords too. Sometimes could be the cord ends, the part that connects with the spark plugs or the distributor cap that cames loose, try to tight them too.
[Image: AEU86 AE86 - ae86 running like shit HELP]
Cump“s
Filipe Oliveira
04-18-2007, 07:10 PM
Did you check if the injector are connected?
04-18-2007, 07:44 PM
Clean the injectors.
Baddog had such issue in the past - one injector clogged...
04-19-2007, 12:17 AM
i was thinking injectors too.but its flooding its self and back firing.
so i will clean the injectors and get a ignitor any other checks?
04-19-2007, 10:22 PM
cleaned all injectors but its running a tiny bit better still feels like 70bhp Angry
04-20-2007, 10:28 AM
Check the plug leads are connected in the correct firing order.
Cheers... jondee86
  No idle below 2000 rpm rich running Steller Engineering 3 2,799 11-30-2022 02:45 PM
Last Post: RolanTHUNDER
  Running issues sam3007 6 4,498 06-26-2022 01:34 PM
Last Post: Dave W
  4age 16v running roughly - diagnostics shows unknown code Ryo 8 10,118 11-09-2020 10:51 AM
Last Post: totta Crolla
  Anyone running DIY Coilovers? Rasteirinho 8 15,645 11-19-2013 10:30 PM
  AE86 dash and running lights gone out Mikezore 10 22,412 01-11-2013 07:16 PM
Last Post: Mikezore
