ae86 running like shit HELP
04-18-2007, 03:57 PM
its only running on two clynders because when you take out plugs 1 and 4 the exhaust dosnt change its note.did compression test and that was perfect.put a new rotor arm and cap on still no change.so i put brand new leads and plugs and its still doing it.
whats next? |
04-18-2007, 04:29 PM
tezza Wrote:whats next? Igniter maybe... Toyota scrap yard car park = AE92GTi - AE82GT - KE30 - KP62 |
04-18-2007, 06:33 PM
ye i was thinking the Igniter i will get a new one and see.
04-18-2007, 06:51 PM
Igniter could be the cause, but you said:
Quote:its only running on two clyndersThis tells me that you have spark on the other two cylinders, correct? Because you have a spark, doesnt matter if it is in only one cylinder, it spaks. Try another spark cords too. Sometimes could be the cord ends, the part that connects with the spark plugs or the distributor cap that cames loose, try to tight them too. CumpĀ“s Filipe Oliveira |
04-18-2007, 07:10 PM
Did you check if the injector are connected?
Sarcasme is just one of the things I offer Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch |
04-18-2007, 07:44 PM
Clean the injectors.
Baddog had such issue in the past - one injector clogged... |
04-19-2007, 12:17 AM
i was thinking injectors too.but its flooding its self and back firing.
so i will clean the injectors and get a ignitor any other checks? |
04-19-2007, 10:22 PM
cleaned all injectors but its running a tiny bit better still feels like 70bhp
04-20-2007, 10:28 AM
Check the plug leads are connected in the correct firing order.
Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
No idle below 2000 rpm rich running | Steller Engineering | 3 | 1,414 |
Running issues | sam3007 | 6 | 2,742 |
4age 16v running roughly - diagnostics shows unknown code | Ryo | 8 | 7,190 |
Anyone running DIY Coilovers? | Rasteirinho | 8 | 13,560 |
AE86 dash and running lights gone out | Mikezore | 10 | 19,032 |
01-11-2013 07:16 PM Last Post: Mikezore |
