ae86_sr20 drift cam
12-23-2007, 07:33 PM
ae86_sr20 drift cam
Exedy flywheel/clutck kit from MCNsport
Will be run on this HKS fcon vpro and GT-RS turbo Polycarbonate windows TURBO'D HACHI |
12-23-2007, 07:40 PM
ae86_sr20 drift cam
TURBO'D HACHI |
ae86_sr20 drift cam
Engine ready to be re-assembled..
TURBO'D HACHI |
12-23-2007, 07:48 PM
ae86_sr20 drift cam
New winscreen and poly windows fitted
TURBO'D HACHI |
ae86_sr20 drift cam
At long last the engine been fitted
18" GTRs on the rear TURBO'D HACHI |
12-23-2007, 07:53 PM
ae86_sr20 drift cam
Heading away to be wired up
TURBO'D HACHI |
12-23-2007, 07:54 PM
ae86_sr20 drift cam
New 3" downpipe
6 new Defi guages & link controller Parked up in WKDimports..600hp D1GP silvia on lift TURBO'D HACHI |
12-23-2007, 08:01 PM
ae86_sr20 drift cam
Heres a run down on the cars spec so far..
ENGINE *HKS stage 3 head *HKS camshafts *HKS 87mm piston kit *HKS 1.2mm headgasket *HKS tubular manifold *HKS GT-RS turbo *HKS adjustable actuator *HKS air filter *HKS Fcon Vpro ecu (standalone) *550cc injectors *Blitz turbo elbow *3" downpipe *Custom 3" full exhaust system *ARP headbolts *Steel lifters *Exedy flywheel/clutch kit *Trust oil cooler & filter relocator *Custom Front mount intercooler & hard pipe'n *Custom wiring loom SUSPENSION/BRAKES *Cusco coilovers (front & rear from 180sx) *Cusco adj top mounts (front & rear) *Cusco adj rear camber arms *Cusco adj rear toe arms *Cusco front tower bar *Cusco pillow tension rods *Extra lock tie rod arms *Rosejointed nissan wishbones *180sx front hubs *R32 skyline front discs & calipers *S14 silvia rear hubs/discs/calipers *Braided brake lines *Solid rear axle bushes *Mintex racing pads *180sx rear axle *Nismo 2way LSD *4.3 cwp INTERIOR *2 x Cobra hardback seats *2 x 6 point harneses *17" vertical hyd handbrake *25L aluminium tank with swirlpot *Bosch fuel pump *Hi-flow fuel filter *Carbon battery box & drycell battery *Uras short shifter *Nismo gearknob *Custom dashboard *Defi fuel pressure guage *Defi oil pressure guage *Defi oil temp guage *Defi water temp guage *Defi boost guage *Defi 80mm tacho *Defi link controller *Greddy profec boost controller *Apexi rev/speed meter *Dead man switch/push button start *OMP 7 point bolt-in cage with door bars EXTERIOR *Origin full bodkit (front/back/sides) *Origin carbon fibre vented bonnet *J-blood wide arch kit (quarters/wings) *Jubiride rear spoiler *Smoked rear lights *FRP Doors *FRP Bootlid *Polycarbonate windows all round (except windscreen) *Headlights replaced by 2 round spots either side *18x9.5 Rota GTR's on rear (245/35) *16x8 Rota grids on front (195/45) *Carbon mirrors TURBO'D HACHI |
12-23-2007, 08:02 PM
ae86_sr20 drift cam
Then i decided i wasnt happy with paintwork so i sent it to EDS bodyworx to be rubbed down and repainted in a brighter white..
TURBO'D HACHI |
12-23-2007, 08:07 PM
ae86_sr20 drift cam
Here is a pic i took of the cam earlier this week,much happier with the paintwork this time
TURBO'D HACHI |
project "twin cam 16" another AE86... | fax0815 | 11 | 18,205 |
11-19-2011 09:05 AM Last Post: BOOMEX |
Corolla GT-Z twin cam 16 (4A-GZE) | danielvanderwoude | 24 | 28,857 |
10-05-2010 08:18 PM Last Post: robokill |
