ae92 shocks
01-11-2007, 12:05 PM
ae92 shocks
are these a direct replacement (no mods needed) for my lowered hachi ?
01-11-2007, 12:17 PM
ae92 shocks
Alimonos,
Ae92 shocks require you to either use a 6cm spacer (not recommended) or shorten your struts casing (recommended). The AE92 shocks have a much shorter body then the AE86 shocks.
If you do not want to alter your struts, buy AE86 shocks but you need to realize you should not lower your car to much or your shocks may become less effective.
Read more here:
http://www.club4ag.com/faq%20and%20tech_...ersion.htm
01-11-2007, 12:57 PM
ae92 shocks
thanks a lot Mux !!!
01-11-2007, 01:00 PM
ae92 shocks
This is a pretty cool picture I found on Club4AG forums - shows the most popular ways that can be used when modifying the struts for new shocks and springs.
As you can see, it's a good idea to both shorten the strut slightly and then use a small spacer under the shock. Cutting the whole 60mm off the strut would probably drop the car too much to be comfortable in street use.
01-11-2007, 01:41 PM
ae92 shocks
I use AE92 front inserts.
AE86 housing was cut 30mm. I use 30mm steel inserts under shock inside shock housing.
01-11-2007, 01:48 PM
ae92 shocks
My springs have lowered the car about 4cm so i think i'll follow your method Jammie !!! :wink:
01-11-2007, 02:50 PM
ae92 shocks
so what if u use the new t3 to spacer would u still have to use another spacer under the shock ? Dumb question
[Image: AEU86 AE86 - ae92 shocks]
01-11-2007, 02:53 PM
ae92 shocks
Firehawk, very cool picture! really sums it up very nicely!
01-11-2007, 02:57 PM
ae92 shocks
mr monster Wrote:so what if u use the new t3 to spacer would u still have to use another spacer under the shock ? Dumb question
http://samodisel.lorddigital.com/razni/A...C_3422.JPG
http://samodisel.lorddigital.com/razni/A...C_3423.JPG
This is CLOSE-look at the under-shock spacer (this particular one is in Mux at the moment, you can see small picture in his project thread).
01-11-2007, 03:09 PM
ae92 shocks
i 've already installed the T3 spacers so the only thing to do is cut 3mm of the strut on the upper section ?
  rear bilstein B6 shocks 2 types what to choose? Ryo 5 4,127 07-25-2021 04:41 AM
  KONI Sports shocks for the AE86... jondee86 11 22,134 09-08-2017 03:38 AM
Last Post: jondee86
  Question about KONI shocks for an AE92 Apsogos 1 4,369 09-13-2013 07:40 AM
Last Post: Apsogos
  ae92 external thermostat housing plumbing? danny 86 2 5,382 08-15-2013 12:38 AM
Last Post: fax0815
  Annoying sound (Ae92 hatch gti) Apsogos 2 4,798 01-02-2013 12:13 PM
Last Post: Apsogos
