ae92 shocks
01-11-2007, 12:05 PM
ae92 shocks
are these a direct replacement (no mods needed) for my lowered hachi ?
AE86 FANATIC!!! |
01-11-2007, 12:17 PM
ae92 shocks
Alimonos,
Ae92 shocks require you to either use a 6cm spacer (not recommended) or shorten your struts casing (recommended). The AE92 shocks have a much shorter body then the AE86 shocks. If you do not want to alter your struts, buy AE86 shocks but you need to realize you should not lower your car to much or your shocks may become less effective. Read more here: http://www.club4ag.com/faq%20and%20tech_...ersion.htm Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
01-11-2007, 12:57 PM
ae92 shocks
thanks a lot Mux !!!
AE86 FANATIC!!! |
01-11-2007, 01:00 PM
ae92 shocks
This is a pretty cool picture I found on Club4AG forums - shows the most popular ways that can be used when modifying the struts for new shocks and springs.
As you can see, it's a good idea to both shorten the strut slightly and then use a small spacer under the shock. Cutting the whole 60mm off the strut would probably drop the car too much to be comfortable in street use. |
01-11-2007, 01:41 PM
ae92 shocks
I use AE92 front inserts.
AE86 housing was cut 30mm. I use 30mm steel inserts under shock inside shock housing. |
01-11-2007, 01:48 PM
ae92 shocks
My springs have lowered the car about 4cm so i think i'll follow your method Jammie !!! :wink:
AE86 FANATIC!!! |
01-11-2007, 02:50 PM
ae92 shocks
so what if u use the new t3 to spacer would u still have to use another spacer under the shock ?
01-11-2007, 02:53 PM
ae92 shocks
Firehawk, very cool picture! really sums it up very nicely!
01-11-2007, 02:57 PM
ae92 shocks
mr monster Wrote:so what if u use the new t3 to spacer would u still have to use another spacer under the shock ? http://samodisel.lorddigital.com/razni/A...C_3422.JPG http://samodisel.lorddigital.com/razni/A...C_3423.JPG This is CLOSE-look at the under-shock spacer (this particular one is in Mux at the moment, you can see small picture in his project thread). |
01-11-2007, 03:09 PM
ae92 shocks
i 've already installed the T3 spacers so the only thing to do is cut 3mm of the strut on the upper section ?
AE86 FANATIC!!! |
rear bilstein B6 shocks 2 types what to choose? | Ryo | 5 | 3,025 |
KONI Sports shocks for the AE86... | jondee86 | 11 | 20,226 |
Question about KONI shocks for an AE92 | Apsogos | 1 | 4,005 |
09-13-2013 07:40 AM Last Post: Apsogos |
ae92 external thermostat housing plumbing? | danny 86 | 2 | 4,964 |
08-15-2013 12:38 AM Last Post: fax0815 |
Annoying sound (Ae92 hatch gti) | Apsogos | 2 | 4,308 |
01-02-2013 12:13 PM Last Post: Apsogos |
