air fuel ratio gauge!
03-10-2008, 12:14 AM
does any1 know how 2 wire up/install a afr gauge 2 a 86?!
ive got a gauge with 3 wires, a red, black, and blue! and need 2 know where they wire up 2! my 02 sensor on the 86 has 1 wire, black in colour. im guessing 1 of the coloured gauge wires go2 this, not sure which 1 tho?! And the other 2 wire up2 wot?! can any1 help me out, or has any1 wired up a afr gauge b4 thanks guys |
03-10-2008, 01:28 PM
02 sensor on the 86 has 1 wire, black in colour --> thats your signal
and the other 2 wires on the AFM is (+) and (-) |
03-10-2008, 10:05 PM
Gtsi-R Wrote:02 sensor on the 86 has 1 wire, black in colour --> thats your signal sorry yea my 02 sensor has 1 black wire. wot do you think the + and - wire in2? do you think there just a feed to make the afm gauge work? |
03-11-2008, 11:04 AM
jup I believe that just is feed.. like all the other gauches it has got 1 signal wire and feed!
it is a small band O2 sensor reaction that I got for this sensor from a salesguy @ zerospec(specialized in Subaru Impreza Turbo), that it is a smallband sensor and will only work good at full trottle. for the rest to check your O2 continiously you will need a wide band lambda and gauche but i do not know annything about that yet.. and they are much more expensive.. cheers roel |
03-11-2008, 10:00 PM
Gtsi-R Wrote:jup I believe that just is feed.. like all the other gauches it has got 1 signal wire and feed! yea ive tryd finding a wide band o2 sensor, and they are expensive! ok thanks for ye help, are c how i get on wiring the gauge up |
03-14-2008, 03:13 PM
Buy Bosch LSU4 sensor from VW shops in USA, relative cheap (<80 USD shipped).
03-17-2008, 11:33 AM
WBO2 sensor needs a controller electronic for heating as well as to generate narrowband (programmed) signal. Without heating, the sensor itself didn't last too long...
Narrowband sensors (and AFR gauges attached to it) is not really a solution to monitor proper ratio, it's not more then a lean/rich light. Check wbo2.com for further info. http://www.ae86.hu |
Fitting Air Con (No PS) to LHD AE86 | pack | 7 | 3,946 |
01-07-2024 11:36 AM Last Post: CCB |
EUDM gauge cluster | banpei | 22 | 4,143 |
08-15-2023 10:48 PM Last Post: banpei |
Air Cleaner Assembly | Hama86 | 7 | 9,175 |
10-29-2018 03:28 AM Last Post: Hama86 |
AE86 4age engine not starts crank ok backfires to air intake | Ryo | 18 | 16,911 |
08-16-2018 01:36 AM Last Post: Bean |
Water Temperature Instrument not moving - Sender Gauge | Hama86 | 8 | 7,491 |
12-06-2017 06:48 PM Last Post: Bean |
