are sr5 rotors the same as gt-s?
07-28-2013, 04:54 PM
http://www.autoanything.com/brakes/77A75...ingid=274x
that link has the rotors i wanna buy but the only sub model i can choose is gts , will it fit a sr5?
07-28-2013, 07:51 PM
Yes..as far as I've seen the front brakes are the same on both models.
07-28-2013, 11:54 PM
USDM GTS and SR5 had the same vented discs in front. But the JDM
AE85 version (=SR5) and some other markets had non-vented front
discs. And you can't swap in vented discs without changing the calipers.
Check if you have vented or non-vented before buying.
Cheers... jondee86
  where to start on sr5-GTS swap dinkers542 0 3,406 12-20-2014 02:13 AM
Last Post: dinkers542
  4age blue top from MR2 same intake manifold? dinkers542 8 10,981 11-02-2014 05:24 PM
Last Post: ditn
  sr5 coupe breaks? help!!!! 86_ae86_coupe 10 11,500 11-16-2011 06:31 AM
Last Post: 86_ae86_coupe
  GZE swap in a SR5 TomTom15 3 4,556 11-04-2011 12:30 PM
Last Post: MatthewG
  disc rotors - options? Apolan 13 13,774 07-19-2011 03:38 PM
Last Post: Hachi
