brake light always on
08-24-2013, 09:02 PM
kawo Wrote:Yeah, I had located the switch. Although I had disconnected the rear lamp to make it not lit when the car is parked. It seems the brake light circuit is still working and my battery is drained after 5 days parked.
The switch is firmly attached to the pedal when the pedal is not pressed.
Now, I just disconnect the plug to the sensor, and the brake like is OFF.
I don't know how to adjust the switch/sensor, maybe I have to buy a new one?
I see, well it is true that if the lights won't go off if you don't disconnect the battery terminal it will drain the battery out. If you don't know how to adjust it I'd say just buy a new one, they aren't too difficult to adjust it should be pretty straight foward, it isn't a part that goes bad often but they do sell new ones for a reason. I'd say order a new one and try it out.
  PWR light issue and no brake fluid after winter storage magpie 10 2,622 05-25-2023 08:09 AM
  Brake master cylinder for FC3S brake conversion Hachi Go 8 14,172 03-03-2011 12:06 AM
Last Post: filh
  left turn signal always flashes. bulbs are good Mitchen 1 3,126 07-27-2010 12:33 AM
Last Post: Mitchen
  How to bleed brake system after master brake replacement Ivan141 12 19,157 09-18-2005 11:21 PM
