cams cams cams
09-03-2013, 04:06 AM
cams cams cams
No need to get tense Angry In these forums, just as in real life, a discussion
on one thing can easily lead to another. I believe the OP received the
information he was after. and from that point on the topic meandered on
to other related matters... some of them quite informative Thumbs up!
Cheers... jondee86
09-04-2013, 04:26 PM
cams cams cams
WOW what happened to the thread while i was gone!!! Tongue
loads of reading for me now
*edit
Thanks for all the info guys Thumbs up! looking at what people have suggested i think a more fast street setup would be suitable to get the gains I'm looking for. I have another rolling road day booked with a different garage so we'll see how similar the figures are.
[Image: AEU86 AE86 - cams cams cams]
09-04-2013, 09:17 PM
cams cams cams
jondee86 Wrote:And for some interesting reading, the main article here...
http://www.popularhotrodding.com/tech/11...ine_dynos/[/img]
Cheers... jondee86
another good read concerning dynos and reality....
http://www.modified.com/tech/modp-1005-d...index.html
Dan -
09-04-2013, 09:25 PM
cams cams cams
If you want 'drop in' cams then you would not be able to use the Catcams as the lift is too high and a fair bit of material needs to be removed from the head.
The piper cams are I believe the same as the ones Raw engineering supply in their 160hp kit and the Kent cams are similar to the Piper ones.
09-04-2013, 10:07 PM
cams cams cams
totta Crolla Wrote:If you want 'drop in' cams then you would not be able to use the Catcams as the lift is too high and a fair bit of material needs to be removed from the head.
I got the ...138 from catcams with 9.5mm lift on the intake side and it cleared my head with space to spare...
AE86 ex-daily
09-04-2013, 10:31 PM
cams cams cams
The link goes to cams with 10.5mm lift and on my head with the 9.5mm lift cams there was only just room, certainly not 1mm iirc it was around 0.6mm
clearance.
09-04-2013, 11:53 PM
cams cams cams
totta Crolla Wrote:The link goes to cams with 10.5mm lift and on my head with the 9.5mm lift cams there was only just room, certainly not 1mm iirc it was around 0.6mm
clearance.
10.5 does NOT clear....
Dan -
09-05-2013, 12:48 AM
cams cams cams
Actually Bean as I think you know I have the same cams as you and mine have good mid range power and then a nice boost in power at around 6000rpm as well as an engine note change.
I have mine set as per the lift @ TDC suggested by the manufacturer.
How are yours performing ?
09-05-2013, 11:14 AM
cams cams cams
Can't say, the car and engine are still in the container somewhere on the sea. Hopefully by spring I'll have everything running and mapped.
Once this is done I'll see if I switch to some bigger cams (...148 or 149).
AE86 ex-daily
09-12-2013, 12:34 PM
cams cams cams
If i was looking at getting the catcams is there a dealer in the UK or will i need to go direct to catcams?
