cams cams cams
08-30-2013, 12:26 AM
superli Wrote:look at this post you will see makkuro he reached your goal.As oldeskewltoy will tell you... increased cam duration will require raised compression to get the best out of the cams (rule of thumb ![]() Note that makkuro cut the head and used a thin metal head gasket when re-building his engine. He got 134 rwhp (and wheel hp is the only accurate measure of hp). So if you already have 127 rwhp, a set of cams should be all you need. But if that 127 hp is engine hp back-calculated from wheel hp, then it will take more than a set of cams. Pedantic... yes ![]() caused by people "guessing" engine power, based on wheel hp dynometer measurements, and it pays to be crystal clear when seeking advice. WHEEL HP IS THE ONLY VALID FIGURE... ALL ELSE IS BS!!! Unless you are using an engine dyno of course ![]() Cheers... jondee86 |
Messages In This Thread |
cams cams cams - megabob - 08-29-2013, 01:31 PM
[] - jondee86 - 08-30-2013 12:26 AM
[] - Alex170984 - 08-30-2013, 04:53 PM
[] - oldeskewltoy - 08-30-2013, 08:53 PM
[] - oldeskewltoy - 09-04-2013, 09:17 PM
[] - totta Crolla - 09-04-2013, 09:25 PM
[] - totta Crolla - 09-04-2013, 10:31 PM
[] - oldeskewltoy - 09-04-2013, 11:53 PM
[] - totta Crolla - 09-05-2013, 12:48 AM
[] - Alex170984 - 09-12-2013, 02:49 PM
[] - Alex170984 - 09-12-2013, 02:51 PM
[] - Alex170984 - 09-13-2013, 02:56 PM
[] - oldeskewltoy - 09-13-2013, 07:30 PM
[] - oldeskewltoy - 09-20-2013, 07:44 PM
[] - totta Crolla - 09-20-2013, 11:44 PM
[] - Alex170984 - 09-23-2013, 03:11 PM
[] - totta Crolla - 09-24-2013, 10:44 PM
[] - Alex170984 - 10-24-2013, 01:17 PM
[] - Alex170984 - 10-24-2013, 04:47 PM
[] - oldeskewltoy - 10-24-2013, 10:46 PM
