camshafts
11-10-2004, 08:47 AM
camshafts
The parts are cheaper here http://www.todaracing.com/products/toyota/index.html
Thats a really nice kit!
Michel
Daily driver: Seat Leon Cupra V6
Summercar: E30 M3 Cecotto
Projectcar: AE86
11-10-2004, 09:30 AM
camshafts
8500E is ridiculous. Spending those amounts of money is strictly for those with to much money and not enough knowledge.
What Ivan says, about pushing 600hp, is a bit over the top. But for that money I could build a 400bhp daily driver anyday. And don't come running with the "no experience with tuning" stories. I consider taking your money to a tuning shop and letting them make your decisions as no experience. And gullible as well. Just opening up a set of brochures on the internet isn't going to learn you anything and shure as hell won't help you make an informed choice.
Anyway...400bhp. Give me the money and I'll build it for you. Would probably have an extra set of high boost, high octane maps too. Mind you..I'm not claiming any reliability when you decide to actually use it.
11-10-2004, 10:32 AM
camshafts
HAHAHAHA 8500 euro
then you can buy
blacktop
1500
ecu
2200
camshafts
1200
and you have over 200bhp :-)
Buy camshafts
272 with 7.9 lift than you can reach 150 with standard tvis
11-10-2004, 11:08 AM
camshafts
i got an offer from someone 2 camshafts 272 degrees for 320 euro`s,sounds like a good deal to me
11-10-2004, 11:30 AM
camshafts
There is only so far you can go with the duration of the cams before the stanadard ecu can cope. I was lead to belive that running 256/264 with a high lift was as far as you can go without needing aftermarket ECU ?
11-10-2004, 12:00 PM
camshafts
For about 3500US (probably less, MAYBE a little more) I could build a 600BHP AE86.
11-10-2004, 12:02 PM
camshafts
And what will it cost to build a reliabel 200hp engine for the AE86?
Michel
Projectcar: AE86
11-10-2004, 12:06 PM
camshafts
About 1500US
11-10-2004, 12:21 PM
camshafts
AndrE86 Wrote:@ The Doctor
How do you know that wil cost about 8500 euro??
the price (excl. BTW) stood on the site a while ago. It was around 7000 euro's, so with btw it's around 8500.
But it has been removed, to not to scare anybody i think Smile
11-10-2004, 02:32 PM
camshafts
Hmmz 272 cams as long as the lift is lower than 8.1 you can use them with the standard ECU.
For 320 do me one pair also :-)
the prob is you will have less power in low rpm's meaning your block will rev upto 7400 before it reaches its peak rpm
Well if you want around 150-160 you want the same as me
check my 4age topic
81.5 bore
272 cams
flowed head
4-1 header
60mm downpipe
doing this will reach around 150-160 easier and recommended is
RX7 fuelpump (or just a one with more capicty)
Bigger injectors (295cc)
trust me then place a nice open air filter and it will be faster
(lightend flywheel would be great addition)
  4AGE camshafts (again) Alex170984 26 29,354 03-19-2013 02:41 PM
Last Post: Alex170984
  What camshafts would be nice? PatrickAE86 44 39,861 08-25-2010 01:06 PM
Last Post: Uzelac
  9.5mm lift camshafts with OEM followers... anyone? apardal 9 8,965 10-15-2008 03:24 PM
Last Post: robokill
  4A-GE with 264ยบ HKS Camshafts running very rich apardal 23 45,512 12-09-2006 12:28 AM
Last Post: ZDoman
  New camshafts for 4age -> 160hp harkes 14 14,345 12-31-2005 08:39 AM
Last Post: BenR
