can I install a lamda sensor?
05-25-2009, 06:45 PM
i own a 84 2 door Levin and my question is if i can install a lamda sensor and how?
how about a map sensor?
05-25-2009, 10:24 PM
If you can get the ECU from an early JDM AE86, you can run both
the lambda sensor and MAP sensor. What I don't know is if the plugs
match up, or if they have to rewired.
Some early Euro spec ECU's use MAP but not O2... and ASFAIK some
run AFM and O2. There are different combinations according to the
market in which the car was first sold.
Cheers... jondee86
Wink Can Wing Mirror Glass be Replaced? chrisae86 1 1,220 03-05-2023 09:34 PM
  Lambda sensor wiring sam3007 10 4,622 05-23-2022 10:00 PM
Last Post: The Doctor
  Can you convert your 86 back too the original state? gh0st 7 3,039 04-25-2022 04:25 PM
Last Post: gh0st
  Can you seperate trueno kouki bumper lights into zenki bumper lights? gh0st 17 8,287 12-19-2021 11:58 PM
Last Post: gh0st
  Can you identify this wheels? Will they fit AE86? Ryo 8 10,555 09-08-2021 12:48 PM
Last Post: Ryo
