catcams
12-17-2014, 11:29 PM
(This post was last modified: 12-17-2014 11:35 PM by Bean.)
catcams
I know I still need to do some porting on the T3 manifold and your recommend adjustment on the intake roof and oil pump anyway. But it would be sad not to go for them in the end (got to put your porting into good use) as I wanted those from the beginning or the ...149s which have even more lift and slightly more duration. If all goes well who knows I might get to 200hp (@engine) after all - OK 190 will do too
It's not my daily anymore and bottom end can't get much worse. I'm finally might have found a place to work so this will speed up progress including the custom header But I'm getting ahead of myself - one piece at the time. Will need to call you sometime soon as I'd like your input/experience on a different matter. AE86 ex-daily |
12-18-2014, 03:04 AM
catcams
(12-17-2014 11:29 PM)Bean Bandit Wrote: Will need to call you sometime soon as I'd like your input/experience on a different matter. Can also email me... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
