center shaft bearing
03-27-2009, 01:06 PM
Hi
On a quest for center shaft bearing for T50. Geniuine Toyota part number is 37230‑12050. EPC looks like this: Does anyone have a better picture or maybe even measures of inner diameter and hole Centers ? Have been looking on web but couldn't find it. But.. important thins is i found some bearing that is i think identical and it is definitly much cheaper. To make sure i need to compare it to our genuine bearing. This is the picture of the one i found: This one measures: Internal Dia: 1.181 = 3cm Hole Centers: 5.709" = 14.5cm Thanks, regards |
03-27-2009, 06:23 PM
"Tämmösellä modernilla autolla, niin mun mielestä, ei tämmöstä kisaa voi ajaa. Tää käy kunnon päälle eikä riitä aivot tähän touhuun!" ""With a modern car like this, in my opinion, a competition like this can't be driven. It's too physical and your brains can't cope with this stuff" -Henri Toivonen 2.5.1986- http://www.youtube.com/watch?v=OwgB4Xs4LVQ |
03-27-2009, 11:57 PM
Great find, regular price is ~200$!
Thanks I'l try to bid it, but for future knowlege i hope we could find out much cheaper bearing |
03-28-2009, 01:09 AM
Can't you just replace the actual bearing then ?
03-28-2009, 01:50 AM
How?
03-28-2009, 06:11 AM
I've done a bit of research here and there is a vastly cheaper bearing that is 95% correct!
You can see where I had to modify the replacement. The manufacturer is Powertrain Industries, part number is 2380-40 Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
04-01-2009, 04:46 PM
yaeh.. i found many that are supose to fit, everything on hiluxes and similar trucks from 1980's will fit with little adoption:
http://cgi.ebay.com/ebaymotors/Toyota-Pi...ccessories http://cgi.ebay.com/ebaymotors/84-95-Toy...ccessories http://cgi.ebay.com/ebaymotors/84-95-TOY...ccessories http://cgi.ebay.com/ebaymotors/99-TOYOTA...ccessories Only the wings need to be modified, rubber and bearing are 100% exact fit |
Restoring original pizzacutter center caps | banpei | 17 | 8,638 |
06-24-2021 10:58 PM Last Post: banpei |
Play between steering column and intermediate shaft after manual rack sonversion | DaLanZhu | 5 | 6,714 |
Steering shaft issue | Ryo | 15 | 12,633 |
11-19-2018 09:52 AM Last Post: Ivan141 |
20v mains & big end bearing | izanagi | 9 | 10,323 |
12-26-2016 12:42 PM Last Post: pack |
AE86 roll center adjusters for Carina | nyberrg | 9 | 12,204 |
06-16-2015 02:45 AM Last Post: roman |
