changing from electric moter windows to winders big job?
03-25-2011, 09:27 PM
changing from electric moter windows to winders big job? wats needed? any1 help?
85 trueno project ![]() 01 corolla dailydriver ![]() http://www.facebook.com/profile.php?id=100000579907701 |
03-26-2011, 12:18 AM
You will need:
window regulator for manual windows door panels for manual windows window crank for manual windows The replacement is time consuming, but not especially hard. There is a special tool that makes this easier... 2 suction cups on a strap... that way you can "hold up" the window while removing the regulator Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
03-26-2011, 07:12 PM
ok panels and cranks arent a problem is the regulater hard sourced?
03-27-2011, 04:30 AM
new? not easily available....
used? I'm on the west coast of the USA... I have little knowledge of Irelands used parts... BUT since manual is far more prevalent then power... I say it is likely easy to find said parts It might be cheaper to buy a pair of doors....... ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
03-31-2011, 08:39 PM
would you want to swap your electric parts for my manual parts?
Electric windows | totta Crolla | 0 | 369 |
03-18-2025 11:00 PM Last Post: totta Crolla |
Big wheel problems | gh0st | 16 | 9,018 |
20v mains & big end bearing | izanagi | 9 | 10,832 |
12-26-2016 12:42 PM Last Post: pack |
Front big brake kit | DidiDex | 14 | 19,507 |
10-24-2016 09:29 AM Last Post: FanIsHere |
Changing distributor when carb 4age | izanagi | 14 | 16,343 |
07-04-2016 03:27 PM Last Post: Uzelac |
