clutch size?
03-08-2007, 07:06 PM
clutch size?
Hi,
Today I orderd at the carpartsstore a new clutch for my car.
They searched on serial number and came up with 2 clutches.
Do you know why the 4age has 2 diffrent clutch types?
[Image: AEU86 AE86 - clutch size?]
you can see that the clutch on the rightside a tiny bit larger is.
We're talking about a 1985 4a-ge 16v.
No more Panda..
Tricolor bastard!
03-08-2007, 07:25 PM
clutch size?
I have a -90 AE92 GT-i "red top" small port head and there is 212mm clutch, also I have a -89 AE92 GT-i with T-VIS head and there is 200mm clutch.
03-08-2007, 07:48 PM
clutch size?
kat versio has a different size then nonKat version
03-08-2007, 07:55 PM
clutch size?
can you say which one the non kat version has?
No more Panda..
Tricolor bastard!
03-08-2007, 08:37 PM
clutch size?
kid Wrote:kat versio has a different size then nonKat version
Hmmm... both of those what I have has Katalysator, still different size clutch.
03-08-2007, 09:25 PM
clutch size?
you can switch the sizes..but you need the pressureplate as well as far as i know
03-08-2007, 09:45 PM
clutch size?
The AE86 comes with 200mm clutch.
You can use any 4AGE (not GZE!) flywheel/clutch combo - either 200 or 212mm.
03-08-2007, 09:55 PM
clutch size?
kid Wrote:you can switch the sizes..but you need the pressureplate as well as far as i know
Actually no you canĀ“t.
If you want change the clutches, you have the change also the flywheel.
I just measured it.
Left one is 200mm , right one is 212mm
200mm pressure plate on 212mm flywheel
212mm pressure plate on 200mm flywheel (where is the flywheel ? )
03-10-2007, 09:51 PM
clutch size?
today I installed the new clutch, it was the 212mm clutch.
But when I drove the car I noticed a little, but noticeable Confused vibration from 2k rpm till 3k rpm. At more rpm the engine takes over the vibration.
I used a pre-historic alligment tool to allign the clutch with the flywheel and pressureplate. As far I could see it was fairly in line with the pressureplate and flywheel. Could the vibrating be an result of a very small off balans from the clutch? Can i do much harm?
last question Tongue . Is there a breaking in period for the new clutch?
cheers!
No more Panda..
Tricolor bastard!
03-11-2007, 12:45 PM
clutch size?
Quote:Is there a breaking in period for the new clutch?
Yes. And if you glaze the friction plate - you will buy new clutch shortly Tongue
  Shim size for AM cams kazi 4 5,399 12-18-2017 05:34 PM
Wink Hub size kazi 5 9,971 06-09-2017 10:06 PM
Last Post: kazi
  Camshaft sprocket bolt size? harkes 1 4,765 07-03-2015 12:41 PM
Last Post: Dave W
  Oil plug thread size is M18x1.5 ???? Dino86 5 9,809 06-07-2012 04:54 PM
Last Post: Dino86
  what tires size do i need? slowboy2 10 14,388 05-28-2012 09:26 AM
Last Post: Uzelac
