clutch size?
03-08-2007, 07:06 PM
clutch size?
Hi,
Today I orderd at the carpartsstore a new clutch for my car. They searched on serial number and came up with 2 clutches. Do you know why the 4age has 2 diffrent clutch types? ![]() ![]() you can see that the clutch on the rightside a tiny bit larger is. We're talking about a 1985 4a-ge 16v. I reject your reality and substitute my own! No more Panda.. Tricolor bastard! If it 'aint broke, fix it 'til it is |
03-08-2007, 07:25 PM
clutch size?
I have a -90 AE92 GT-i "red top" small port head and there is 212mm clutch, also I have a -89 AE92 GT-i with T-VIS head and there is 200mm clutch.
03-08-2007, 07:48 PM
clutch size?
kat versio has a different size then nonKat version
03-08-2007, 07:55 PM
clutch size?
can you say which one the non kat version has?
03-08-2007, 08:37 PM
clutch size?
kid Wrote:kat versio has a different size then nonKat versionHmmm... both of those what I have has Katalysator, still different size clutch. |
03-08-2007, 09:25 PM
clutch size?
you can switch the sizes..but you need the pressureplate as well as far as i know
03-08-2007, 09:45 PM
clutch size?
The AE86 comes with 200mm clutch.
You can use any 4AGE (not GZE!) flywheel/clutch combo - either 200 or 212mm. |
03-08-2007, 09:55 PM
clutch size?
kid Wrote:you can switch the sizes..but you need the pressureplate as well as far as i knowActually no you canĀ“t. If you want change the clutches, you have the change also the flywheel. I just measured it. Left one is 200mm , right one is 212mm ![]() 200mm pressure plate on 212mm flywheel ![]() ![]() 212mm pressure plate on 200mm flywheel (where is the flywheel ? ) ![]() |
03-10-2007, 09:51 PM
clutch size?
today I installed the new clutch, it was the 212mm clutch.
But when I drove the car I noticed a little, but noticeable ![]() I used a pre-historic alligment tool to allign the clutch with the flywheel and pressureplate. As far I could see it was fairly in line with the pressureplate and flywheel. Could the vibrating be an result of a very small off balans from the clutch? Can i do much harm? last question ![]() cheers! I reject your reality and substitute my own! No more Panda.. Tricolor bastard! If it 'aint broke, fix it 'til it is |
03-11-2007, 12:45 PM
clutch size?
Quote:Is there a breaking in period for the new clutch?Yes. And if you glaze the friction plate - you will buy new clutch shortly ![]() |
Shim size for AM cams | kazi | 4 | 5,300 |
Hub size | kazi | 5 | 9,819 |
06-09-2017 10:06 PM Last Post: kazi |
Camshaft sprocket bolt size? | harkes | 1 | 4,694 |
07-03-2015 12:41 PM Last Post: Dave W |
Oil plug thread size is M18x1.5 ???? | Dino86 | 5 | 9,676 |
06-07-2012 04:54 PM Last Post: Dino86 |
what tires size do i need? | slowboy2 | 10 | 14,061 |
05-28-2012 09:26 AM Last Post: Uzelac |
