co idle mixture - discussion
07-12-2012, 08:01 AM
Andrax Wrote:Its normal that the CO values are not stable. The ECU is always trying to adjust it, so you wont get a linear value. As said, set it on the factory specs. Anyway, after a few kilometers it will get out of specs again...
Goodmorning!
ok i understood it is not stable,i adjusted them on the factory specs the last time....
but if the ecu will "change"" them which is the meaning of adjusting them?..
4age 16v to FR 20VT
07-13-2012, 02:31 PM
it is very important to inform me ,if the ecu self - adjust the co mixture!
if it does then when i adjust it to the oem specs, then the ecu will change them?
4age 16v to FR 20VT
  No idle below 2000 rpm rich running Steller Engineering 3 1,730 11-30-2022 02:45 PM
Last Post: RolanTHUNDER
  Engine starts/revs but no idle GenkiMotors 17 8,192 11-20-2021 04:12 AM
Last Post: GenkiMotors
  exhaust odor/idle MOT issue Ryo 7 7,810 07-15-2019 09:17 AM
Last Post: jondee86
  20v silvertop idle issue AlexFourTwenty 3 5,404 12-24-2017 03:27 AM
Last Post: AlexFourTwenty
  Silver top low idle AlexFourTwenty 7 10,655 10-16-2017 10:22 PM
