compatibility of rear harnesses
12-20-2014, 02:38 AM
As I am getting ready for my GTS swap I have a question about the rear wiring harness. The car all of my parts are going into is an 85 SR5 from an 86 GTS. Sincr the tail lights are a different design will there be compatibility problems going from Zenki to Kouki?
Thanks, Dinkers |
12-21-2014, 05:05 PM
Compare the wirecoulours, they should be identical, if there is anything in a different place change the pins over.
12-21-2014, 05:08 PM
(This post was last modified: 12-21-2014 05:09 PM by Uzelac.)
AE85 harness doesn't have wires for electric fuel pump, beside identical.
I have AE85 wires in my AE86, so I had to learn |
Rear ae86 rear discs & pad part numbers? | J-86 | 4 | 5,814 |
Adjustable Rear trailing arm/rear 4 links? | lolali | 1 | 4,670 |
10-03-2009 05:17 PM Last Post: lolali |
rear brakes and rear axle questions | fastsaab | 5 | 6,020 |
11-19-2008 05:28 AM Last Post: Chrisso |
steering rack compatibility | mr monster | 3 | 4,289 |
09-29-2006 11:51 AM Last Post: mr monster |
