cooling problems
08-10-2008, 11:30 PM
cooling problems
recently I put a electric fan and only temp. switch that I can find to fit was one that turn on the fan on 85C
and now fan is working almost constantly .
can anybody recommend wright temperature switch?
and what is normal working temp. for 4age bluetop?
thanks
"Faster, Faster, until the thrill of speed overcomes the fear of death." -Hunter S. Thompson
08-11-2008, 01:00 AM
cooling problems
85 is good for racing use
84' AE86 Levin
96' 500HP WRX, powered by landikar
[Image: AEU86 AE86 - cooling problems]
08-12-2008, 05:50 AM
cooling problems
I just wired mine directly to the ignition. No need for a temp switch.
Fully Restored 1985 Corolla GT-S
1987 328ci SR20DET Drift Car
1989 Honda Civic Si-R Current Project
2002 Corolla CE Daily Driver
http://www.TheTunerSource.com
08-12-2008, 12:33 PM
cooling problems
F0Bman Wrote:I just wired mine directly to the ignition. No need for a temp switch.
can you explain this ? post some pictures please.
thanks
08-19-2008, 07:59 AM
cooling problems
Connect the positive end to the IGNITION fuse in the fuse box. This will power up when the key is in, and power down when fully shut off.
08-19-2008, 12:16 PM
cooling problems
Typically, the radiator thermostat will start to open at 82-85 deg and
be fully open at >90 deg. This indicates that the thermostat is trying to
maintain an engine temperature between 85 and 90 degrees. It does
this by adjusting the amount of water flowing thru the radiator.
Electrically operated fans are normally off when the car is traveling at
any reasonable speed. The flow of air thru the radiator is sufficient for
engine cooling. The fan should really only turn on when the car is
stuck in traffic, and there is no airflow thru the radiator due to movement
of the vehicle.
Try locating the temperature switch in a cooler part of the water circuit.
The bottom of the radiator is much cooler than the top. All the factory
temperature switches I have seen are either near the bottom of the
radiator, or in the return pipe.
Don't put your switch in the hose taking water to the radiator !!! If you
do it will run all the time and be really annoying Tongue
Cheers... jondee86
08-19-2008, 08:55 PM
cooling problems
thanks jondee86 !!
that is the info that I need.
I located the temp switch in the lower hose but next to the thermostat , will correct that soon.
thank again Thumbs up!
  Improve 20V Blacktop cooling pack 0 943 06-07-2023 01:18 PM
Last Post: pack
  Big wheel problems gh0st 16 8,002 11-15-2021 10:51 PM
Last Post: gh0st
  Starting problems 4-AGE kouki Hanzo 3 2,595 08-31-2021 06:20 PM
Last Post: totta Crolla
  Problems Mintex M1155 pads Dino86 9 8,789 07-04-2017 11:22 AM
  16v Bigport fuel problems Rascal21 1 4,715 07-04-2015 01:00 AM
Last Post: jondee86
