d3nso's little AE86 N2 build
06-26-2013, 11:54 AM
About the bc-racing coilover-kit, is the height adjustment at it's lowest at the pic's or is there any clearence going lower ? :wink:
Could be one of the coilover options, just interested how it "fits"
Drive fast, or crash when trying...
06-26-2013, 12:13 PM
The Front can put on the ground if wanted, at the rear i can go about 1.5cm lower before it reachs the max lowring the kit offers
The first pic was near stock height btw :wink:
Daily Beater: Civic EG5
Work in progress Car: AE86
06-26-2013, 05:31 PM
What are the f/r spring rates on your set ?
And what do you feel about the handling ? Is it hard as hell, or comfort enough for everyday cruizing..
And btw, what size are your wheel/tyre combo ? Tongue
06-26-2013, 10:35 PM
Springs should be f-8kg/r-6kg.
Hm I drive a 08 Suzuki Swift Sport as daily und the BC is alot harder then the sport setup of the Swift, even on the softest damper setting. But if you like it bit harder dann usual it's good. I would drive it on a daily :wink:
Tires are 195-50-15 Yokohama A539, great Tires.
Wheels are 15x8, offset unknown, will check it next time at the Garage if needed. Smile
06-27-2013, 07:39 AM
No need to check the offset, was just interested on the wheelsize, and the stance.
Thanks alot for all the info, like to hear an opinion on driveability and etc. from someone that actually uses the coilover set rather than someone that sells them, or has looked the specs on internet. Tongue
07-01-2013, 09:45 PM
herzlich willkommen,
sieht sehr schön aus;-)
bist du im Toyota Forum angemeldet?
ist das bc racing eingetragen?habe auch eins in meinem corolla und bereite ihn für den tüv vor ;-)
schau mal hier rein;-)
http://board.toyota-forum.de/showthread....?p=1829434
lg max
[Image: AEU86 AE86 - d3nso's little AE86 N2 build]
07-01-2013, 10:18 PM
Danke, jap bin dort ebenfalls angemeldet, war aber bisher nur passiver mitleser Tongue
Eingetragen ist leider ganichts, muss sowieso erst noch deutsche papiere beantragen, bzw Vollabnahme machen lassen. Da werd ichs mal versuchen ob ich das Fahrwerk durchbekomm, sonst hab ich n Problem, da ich kein Orginalfahrwerk habe :roll:
Gruß,
Timo
08-16-2013, 11:22 AM
So time to update the project.
Since I moved to a new garage nothing reallly changed, because I got no space to work at the car.
But I managed to get this piece of engineering Tongue
Condition is good, seems like it has run >100.000 KM. The bad thing is; no crank and flywheel.
04-08-2017, 07:25 PM (This post was last modified: 04-08-2017 07:53 PM by d3nso.)
Long time no update. Went to University the past Years so no time and money to continue the project. But now I'm restarting the project Hurray!
Spent the last few weeks with taking out interior and started with removing the old undercoating:
This work is a pain to do... Facepalm
04-14-2017, 08:56 PM
Great to see you back on the porject! Thumbs up!
And so much you cleaned up already!
  (Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams oldeskewltoy 5 3,039 09-09-2022 09:07 PM
Last Post: Vaptor
  OST-050 - a VERY special build oldeskewltoy 49 36,338 01-05-2019 07:03 PM
  Beams Levin build mannix20vt 5 9,306 01-27-2016 12:39 AM
Last Post: mannix20vt
  Drift missile build [FIN] TuGeTu 7 20,809 11-09-2015 06:13 PM
  My panda ae86 build Ellzbmx 10 17,598 06-03-2015 10:56 AM
Last Post: Ellzbmx
