engine start up and retractor light
10-05-2013, 03:41 AM
Hi pack,
As my car was a LEVIN, and the previous owner converted it to TRUENO, I have no idea if the relay are in the place it should be.
For the pop-up light, it worked fine with the old fuse box, so the relays should be fine, the problem should be originated from the engine fuse box, which I have no idea if there are different internal connection inside the fuse box.
For my engine start problem, with the old fuse box and new relays, I feel a bit better to get started, after sit for nights, I am able to fire it up at the 2nd try, can you guys suggest what should have gone wrong, it feels like something need to be "warmed up"(the first trial) before it can be fire up.
pack Wrote:The fuseboxes are compatible! And switchable!
I've converted my Levin to Trueno and with the two relays.
The blue under the dash, and the black behind the headlight got my car working with the trueno light display! All correctly! Thumbs up!
10-13-2013, 02:23 PM
So your car is just like mine... An old Levin that is now a Trueno.
Why don't you buy the relays at the Toyota dealership and build a new wiring harness? I did that on my car.... Smile
  Refreshed 20v blacktop first start.. Mylesmck 6 875 10-07-2024 07:55 AM
  ECON and PWR light troubleshooting magpie 3 1,753 07-18-2023 01:28 PM
  PWR light issue and no brake fluid after winter storage magpie 10 2,832 05-25-2023 08:09 AM
  Warm start problem DJexor 5 2,369 03-09-2023 10:15 AM
  Weak spark, doesn’t start. AlexFourTwenty 4 15,541 12-12-2017 03:35 AM
Last Post: AlexFourTwenty
