engine start up and retractor light
10-05-2013, 03:41 AM
Hi pack,
As my car was a LEVIN, and the previous owner converted it to TRUENO, I have no idea if the relay are in the place it should be. For the pop-up light, it worked fine with the old fuse box, so the relays should be fine, the problem should be originated from the engine fuse box, which I have no idea if there are different internal connection inside the fuse box. For my engine start problem, with the old fuse box and new relays, I feel a bit better to get started, after sit for nights, I am able to fire it up at the 2nd try, can you guys suggest what should have gone wrong, it feels like something need to be "warmed up"(the first trial) before it can be fire up. pack Wrote:The fuseboxes are compatible! And switchable! |
10-13-2013, 02:23 PM
So your car is just like mine... An old Levin that is now a Trueno.
Why don't you buy the relays at the Toyota dealership and build a new wiring harness? I did that on my car.... |
Refreshed 20v blacktop first start.. | Mylesmck | 5 | 258 |
10-04-2024 08:30 PM Last Post: Mylesmck |
ECON and PWR light troubleshooting | magpie | 3 | 1,443 |
07-18-2023 01:28 PM Last Post: banpei |
PWR light issue and no brake fluid after winter storage | magpie | 10 | 2,274 |
Warm start problem | DJexor | 5 | 2,099 |
Weak spark, doesn’t start. | AlexFourTwenty | 4 | 14,712 |
