extracted freedom ecu 16v ignition map
08-09-2016, 10:53 AM
(This post was last modified: 08-09-2016 12:44 PM by ditn.)
So i have extracted a 16v ignition map from freedom ecu that was lightly tuned
(Map based) Do you think this map would be a good starting point for my stock engine with other cams?
08-09-2016, 11:38 AM
Sure! That is basically "the perfect" starting point!
08-09-2016, 12:38 PM
(This post was last modified: 08-09-2016 12:41 PM by ditn.)
-.- the first post is now updated
goes from 500 to 9000 rpm other bar is mmgh/kpa Freedom is bit different than other ecus |
08-09-2016, 02:52 PM
To be honest, it's an odd looking map.
you got 576 data point (32x18.), but only 200 are really "useful" (20x10) Appart from that, it should get your engine running. |
08-09-2016, 03:10 PM
Yeah freedom is a bit different
![]() The rpm points are not changable in the older versions 16 points For the mmgh you can choose how much it jumps 25 50 ... Intervals So on an older version it looks weird because injection and ignition use same setting So youre forced to use same settings and cells for both. The newer version can sets freely but i have not found out yet So with those ignitions i can run engine and set fuel cells?
08-09-2016, 05:13 PM
If you don't have crazy compression and / or very low octane fuel, yes you're good to roughly tune the fuel table.
08-09-2016, 05:22 PM
Stock compression and octane 98
![]() At least i think engine is like that mystery engine but i dont see anything like tuning. Will also install knock light from g4. Thanks for answers
08-22-2016, 10:01 AM
(This post was last modified: 08-22-2016 10:15 AM by ditn.)
Car is starting and running.
Letting freedom do the autotune on fuel for now. (Together with afr meter and knock sensor) Here is another map i made based on 1 from internet,it also has alot less points what do you think :
| map sensor cheating? | fdsjakl890 | 8 | 1,942 |
08-26-2025 01:12 PM Last Post: Ivan141 |
| Ignition switch plug and wires | Blaze0010 | 3 | 2,186 |
| AFM to Map Conversion | ps13michi | 3 | 5,159 |
| Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP | mister86 | 12 | 15,314 |
| 20v Silvertop stock ignition timing and fueling maps | Lykowsky | 5 | 16,435 |
