fender holes measure HELP
12-22-2010, 07:14 AM
hi guys
hope an ae86 fan could help me with this issue very simple indee can someone please measure the holes center to center or measure between nuts here is a pic[img name=]http://www.aeu86.org/files/tr/troubelfender_ae86_650.jpg[/img] ++if you have the fender out just do the measure from the center as the pic or if you have it on the car,just do the measure on top and on the center of the nut ++I think is very important not have had a crash cause maybe that can vary the measure what do you think? but most important for me is the measures A=? B=? C=? D=? E=? F=? i think the other fender MUST have the same measures right cause in mine doesnt cheers guys HELP!!! ![]() p.s OFcourse more than 1 opinion and member help will be really apretiate it. ![]() |
12-23-2010, 05:44 PM
sergiocharged Wrote:hi guys oh boy ![]() ![]() |
12-23-2010, 07:33 PM
i'm going to take those meassurements you need after x-mas
12-23-2010, 09:38 PM
A= 60
B=115 C=175 D=200 E=125 F=60 in mm measured from a Trueno wing, but its the same has a Levin, cause I had Levin wings before and they bolt in the same holes. Same on both sides ![]() |
12-23-2010, 10:21 PM
aussiefan Wrote:i'm going to take those meassurements you need after x-mas hehe ok aussiefan would be awesome if youcan help with your measures,to compare cheers ![]() ![]() |
12-23-2010, 10:26 PM
JonnyAE86 Wrote:in mm measured from a Trueno wing, but its the same has a Levin, cause I had Levin wings before and they bolt in the same holes. ![]() ![]() ![]() ![]() ![]() thnks jonnyAE86 thnks im having lunch right now then ill come down to chek your measures. but just 1 doubt what s a trueno wing? and levin wings? are we talking about the same subject? ![]() ![]() ![]() cheers ill chek these measures thks ![]() ![]() |
12-23-2010, 10:41 PM
yeah its the same wing trueno = pop up lights , Levin = fixed headlight version of the ae86
12-23-2010, 11:51 PM
alex-evo Wrote:yeah its the same wing trueno = pop up lights , Levin = fixed headlight version of the ae86 i think no one knows that here... ![]() |
12-24-2010, 03:20 AM
Hachi Wrote:alex-evo Wrote:yeah its the same wing trueno = pop up lights , Levin = fixed headlight version of the ae86 yup ![]() p.s i know trueno = pop up lights and levin fixed ones but wing? hehe i cheked the measures some mm out of distance but...its good i can find a nominal value between the fender and the base thnk you ![]() |
12-24-2010, 03:32 AM
JonnyAE86 Wrote:A= 60 btw jonny i sent you a pm i was cheking your webpage pretty cool chek your inbox ![]() |
brake master cylinder ( 4 holes ) | NBU | 7 | 6,889 |
12-27-2012 04:12 PM Last Post: Bean |
Question: Where I can find this fender flare? | winchi.c | 3 | 5,413 |
05-01-2011 09:58 AM Last Post: Bentley |
I need some info about the plastic under the 2 front fender | Mattolo | 4 | 5,864 |
02-22-2010 01:28 PM Last Post: Mattolo |
Golf Fender Flares for the AE86 (rabbit ??) | gon | 6 | 7,843 |
05-13-2009 08:53 AM Last Post: robokill |
Fender & Rims Combination | Serencebey | 11 | 18,631 |
03-04-2009 11:04 PM Last Post: Serencebey |
