few issues after last drift days, advice needed
08-25-2011, 09:13 PM
Hi, I´ve had a few problems during and after my recent drift days.
Have a quick read through the symtomes and let me know if you experinced someting similiar in the past? And if you know whats wrong Smile
-the freshly rebuild diff started to make noises and i found axial play on the pinion shaft, will dissasemble to check whats the problem...
-on my way home the steering felt strange, compared to before If you steer quick it will bounce back almost a a sec. later but in the opposite direction!!!
Felt horrible on open road, when passing other cars for example...
Anyone got an idea what´s wrong? Only thing I can think of are worn bushings at the rear, everything else has been replaced/checked.
-I got alternating idle some times, but it goes away if you give it a rev and let it go back to idle. Any ideas???
Thanks Big Grin
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
08-26-2011, 03:53 AM
I thinck it's the front wheels bearing Undecided
for the alternating idle. look at your throll cable systeme Wink
SR Team
BURN THE RUBER NOT YOUR SOUL!
08-26-2011, 08:33 AM
fax0815 Wrote:-the freshly rebuild diff started to make noises and i found axial play
If you are using the OEM crush tube for pre-loading the pinion bearings,
it is likely that the crush tube has been compressed due to the high loads
generated by drifting techniques. If this has happened, you will need to
replace the OEM crush tube with a solid spacer and shims.
Cheers... jondee86
  PWR light issue and no brake fluid after winter storage magpie 10 2,807 05-25-2023 08:09 AM
  20 Valve Blacktop smoking after engine flush - why? RolanTHUNDER 2 1,464 11-30-2022 12:09 PM
Last Post: RolanTHUNDER
  Running issues sam3007 6 2,971 06-26-2022 01:34 PM
Last Post: Dave W
  Play between steering column and intermediate shaft after manual rack sonversion DaLanZhu 5 6,971 07-31-2019 11:28 AM
  Brake advice - master cylinder mannix20vt 12 14,371 08-21-2017 03:21 PM
Last Post: Project D
