flip your car over??
07-28-2005, 04:16 PM
In addition to the pictures - just decide and make some gradient limiters (just weld steel pieces to limit the hinges) - otherwise the car will fall when you roll it across vertical position LOL Evil
07-28-2005, 04:24 PM
Those need to be some heavy duty hinges...not to forget you would need the incredible hulk to help you lift the car in this contraption.
07-28-2005, 04:34 PM
Ivan141 Wrote:Those need to be some heavy duty hinges...not to forget you would need the incredible hulk to help you lift the car in this contraption.
Yes, but these hinges can be fabricated from 2 tubes or use hinges for garage doors (buy them from hardware store). About lifting - yes, this is the major drawback - usualy 3 persons can lift any car on that "cradle" :wink:
07-29-2005, 11:59 AM
I prefer those stands, similar to large engine stands, which you bolt onto the chassis to flip the car; I dunno but the forces on the suspension are by far larger and in a unplanned direction from the original design the suspension has to take with this...
07-29-2005, 12:04 PM
PetzK Wrote:I prefer those stands, similar to large engine stands, which you bolt onto the chassis to flip the car; I dunno but the forces on the suspension are by far larger and in a unplanned direction from the original design the suspension has to take with this...
Like this:
[Image: AEU86 AE86 - flip your car over??]
07-29-2005, 01:07 PM
Yes exactly. although those look a bit flimsy, are the stable enough? seems to work for you...
07-29-2005, 03:14 PM
You have to take off the rear end, engine and gearbox otherwise it is too flimsy Smile
  The General Wants Your HACHI! Apolan 5 6,893 11-01-2010 04:56 PM
Last Post: oldskull
  Need your help to vote. Richard 2 4,483 08-04-2010 11:00 PM
Last Post: Richard
  What do you use your hachi for? Apolan 14 12,764 10-11-2007 10:41 AM
Last Post: Nismo
  Your Top Five Cars... TRUENO><ONEURT 58 47,184 08-19-2007 05:43 AM
Last Post: senna
  Your Computer TRUENO><ONEURT 49 38,448 03-23-2007 08:12 PM
Last Post: Akis308
