flip your car over??
07-28-2005, 04:16 PM
In addition to the pictures - just decide and make some gradient limiters (just weld steel pieces to limit the hinges) - otherwise the car will fall when you roll it across vertical position LOL
07-28-2005, 04:24 PM
Those need to be some heavy duty hinges...not to forget you would need the incredible hulk to help you lift the car in this contraption.
07-28-2005, 04:34 PM
Ivan141 Wrote:Those need to be some heavy duty hinges...not to forget you would need the incredible hulk to help you lift the car in this contraption. Yes, but these hinges can be fabricated from 2 tubes or use hinges for garage doors (buy them from hardware store). About lifting - yes, this is the major drawback - usualy 3 persons can lift any car on that "cradle" :wink: |
07-29-2005, 11:59 AM
I prefer those stands, similar to large engine stands, which you bolt onto the chassis to flip the car; I dunno but the forces on the suspension are by far larger and in a unplanned direction from the original design the suspension has to take with this...
07-29-2005, 12:04 PM
PetzK Wrote:I prefer those stands, similar to large engine stands, which you bolt onto the chassis to flip the car; I dunno but the forces on the suspension are by far larger and in a unplanned direction from the original design the suspension has to take with this...Like this: Sarcasme is just one of the things I offer Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch |
07-29-2005, 01:07 PM
Yes exactly. although those look a bit flimsy, are the stable enough? seems to work for you...
07-29-2005, 03:14 PM
You have to take off the rear end, engine and gearbox otherwise it is too flimsy
The General Wants Your HACHI! | Apolan | 5 | 6,922 |
11-01-2010 04:56 PM Last Post: oldskull |
Need your help to vote. | Richard | 2 | 4,501 |
08-04-2010 11:00 PM Last Post: Richard |
What do you use your hachi for? | Apolan | 14 | 12,829 |
10-11-2007 10:41 AM Last Post: Nismo |
Your Top Five Cars... | TRUENO><ONEURT | 58 | 47,290 |
08-19-2007 05:43 AM Last Post: senna |
Your Computer | TRUENO><ONEURT | 49 | 38,528 |
03-23-2007 08:12 PM Last Post: Akis308 |
