flywheel options - What are you using?
04-13-2007, 12:35 PM
EDIT: i changed a topic to poll to see what many of you are using. Please share your experiences..
--------------------orginal post--------------------------- Hi, since im rebuilding my engine now, i would like to know your opinions on the stock flywheel. Im thinking about machining it to make it a bit lighter. Is this a good idea? What the stock weight and what weight should i be looking at for improoved performance but still keeping the car streetable? How much material can be taken off not to compromise the strenght? etc. thanks.. |
04-13-2007, 12:45 PM
http://www.my-acoustic.com/Car/weight_is...weight.htm
http://www.my-acoustic.com/Car/weight_is...wheels.htm Take a look here for some ideas. |
04-13-2007, 07:12 PM
hm, this looks more complicated then i first thought.. lightning the flywheel in the center doesnt make much sense to me, as the weight nearer the center has little (or much lesser) influence on the turning momentum. isnt the point to reduce the momentum so its easier to rev, thus giving better response and increasing the power?
04-15-2007, 11:51 PM
if by any chance you people think im done with this you are teriblly wrong im afraid
![]() ![]() ![]() what nobody has any experience with lighter flywheels or lightning them for your ae's? ![]() |
04-15-2007, 11:55 PM
I know that Toda flywheel weights 3.7 kg.
Vladimir ![]() N/A for life... |
04-16-2007, 12:07 AM
huh, stock silvertop is 6.9 kg, blacktop 5.9 kg.. im guessing ae86 flywheel is even heavier? so 3.7 seems very (too?) light..
04-16-2007, 12:25 AM
Apolan Wrote:im guessing ae86 flywheel is even heavier? so 3.7 seems very (too?) light.. Aprox. 10 kg by Bill Sherwood... TRD for AE86 is aprox. 4,5-5 kg Toyota scrap yard car park = AE92GTi - AE82GT - KE30 - KP62 |
04-16-2007, 05:13 PM
Apolan Wrote:if by any chance you people think im done with this you are teriblly wrong im afraid I cant recall anyone that has lightened the flywheel.. but I do think it is potentially dangerous to do this. Look around for pics of a honda with an exploded flywheel on google, you'll get the picture. It would rip right through the car, and maybe even take a leg along the way if it happens to break. FABRICA MI DIEM, PVNC! |
04-16-2007, 06:18 PM
what are you serious?! now youre scaring me..
04-16-2007, 06:55 PM
A lot of people remove the weight where it is easy to do: the thick center section. A brilliant bit of thinking that...
Stresses are the highest in the center of the disc and the reduction in rotational intertia is the smallest. Darwin award stuff if you ask me. A wheel to steer the front of the car A pedal to steer the rear |
ITB filter options | mister86 | 1 | 3,622 |
12-06-2020 10:44 AM Last Post: Bean |
AE86 starter options | max_ae86 | 12 | 31,321 |
07-28-2019 08:17 PM Last Post: harkes |
light weight Flywheel | filh | 9 | 7,648 |
02-05-2018 05:20 PM Last Post: filh |
AE86 rear suspension options 2018 | Alex | 9 | 11,550 |
01-24-2018 02:25 PM Last Post: mad.matt |
Rear axle options | Dino86 | 13 | 13,633 |
