from which block is this head
03-26-2007, 08:27 AM
from which block is this head[/code]
03-26-2007, 08:37 AM
Looks to me like a 4AC head, but there are probably a lot i could mistake for it =/
03-26-2007, 04:08 PM
It's 4AC head (1.6 SOHC ~85 HP)
I have one around somewhere Smile
Toyota scrap yard car park = AE92GTi - AE82GT - KE30 - KP62
03-26-2007, 04:22 PM
wow....what happen there
dont you or any 1 have a picture ot a 4AC block ......from the top and side
03-26-2007, 04:37 PM
Max_toy Wrote:wow....what happen there
It's my parts car.. I bought it crashed.
Max_toy Wrote:dont you or any 1 have a picture ot a 4AC block ......from the top and side
The block is the same as 4AGE Bluetop 3 rib block (1st gen. 4AGE), except some minore details (position of alternator, etc..)
The best pic I got of the block... i can get you some better pics in a few days, till I find where I put that egine Smile
03-26-2007, 04:56 PM
cool i have a 4AC block at home and a blue top twincam head wanna c if i can do something with it
thanks will wait for pictures ....
03-26-2007, 07:37 PM
So you have these ready ?
Then buy redtop (hi-CR) crank, rods and pistons from Ebay (you can get pistons new for cheap too - "Clevite" brand). Crank and rods are the same as 4AGZE ones. That way you will finish with 10.3CR bigport engine. If you use 0.5 steel head gasket (Ebay again) you will achieve over 10.5CR without even milling the head/block !
PS: 4AG(Z)E crank use 8-bolt flywheel (so 4AC/4AF ones will not apply - they are 6-bolt ones). You can buy Fidanza flywheel + uprated clutch combo or just use 200/212mm 4AGE stock flywheel. Try to buy 4AGE AE86 bellhousing too, else you will have clearance problems with some headers (the clutch slave is on opposite side of bellhousing). You must also find 4AGE alternator bracket (or fabricate it) - the one from 4AC will not apply.
PPS: If you can get 4AG(Z)E for cheap localy (no shipping) - this will be more valuable option.
03-27-2007, 06:58 AM
i currently was given a 16v blue top 4AGe head...with Tvis intake so was think what the....lets try this on the bock ....
  20v BT - which oil pump? Mylesmck 4 2,830 06-21-2022 04:51 PM
Last Post: pack
  Question about 4AG 20v Engine Block CHACAMAN 1 1,654 06-10-2022 05:17 PM
  4AGE block differences explained (incl. some eyecandy) Bean 46 87,802 05-05-2019 04:03 AM
Last Post: Rocker100
  BT head with ST block. CHOPKIN2 6 7,210 02-06-2018 06:27 PM
  Rim width. Which is best.... Dino86 5 6,803 01-07-2017 03:09 PM
Last Post: Dino86
