help!!!!
02-17-2011, 08:08 PM
help!!!!
Hi guys,
The other day I went to pick up my car and I went for a test drive and pushed the car a bit to see why its having a miss between 0 - 2500 rpms and suddenly this metal sound came and a kind of a loud noise is coming from the GB now! It goes off when I press the clutch which means it can be the RELEASE bearing BUT... when I put to 2nd the sound changes to a deeper noise and the vibrations become bigger. Can this be a problem with a GB or can it be just the release bearing?? Please help and advice.. Cheated on my いたずらな女の子 and now I can't get enough of her.. |
02-19-2011, 12:24 AM
help!!!!
Mayby its the driveshaft? I mean you said it stops if you press the clutch, wich indicates more to something in the clutch region.
Take it of to inspect. ![]() 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
03-06-2011, 08:39 PM
help!!!!
its the gearbox.. one of the bearings in the counter wheel shattered
![]() a few teeth from 2nd and 3rd also gone ![]() ![]() ![]() searching for a new T50.. but seems like I need to go to a W58.. any easier GB change than a W58? I hear drive shaft changes need to be done as well ![]() Cheated on my いたずらな女の子 and now I can't get enough of her.. |
