help!!!
05-06-2009, 08:06 PM
help!!!
how much fuel pressure do i need to run my redtop !????
05-07-2009, 07:26 AM
help!!!
or about how many psi does my fuel pump need to produce to keep it on???
05-07-2009, 05:53 PM
help!!!
From memory, the fuel rail should be at around 35 psi and the pump
should be capable of producing 50-60 psi. The engine will probably run with less than 35 psi in the rail, but will be lean. Rail pressure is maintained by the Fuel Pressure Regulator on the return end of the rail. Cheers... jondee86 |
