highest lift and duration possible for stock ecu
02-19-2009, 02:31 AM
tolisspi Wrote:Good numbers. So 130 hp crankshaft I'm guessing a bit closer to 135. It is rwd drivetrain loss.... Runs on a stock ECU idles at 850(does need to be adjusted about 1/8 turn for every 15-20 f degrees of change) It passes Oregon emissions sniffer too Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
02-19-2009, 10:06 AM
oldeskewltoy Wrote:what do you mean?tolisspi Wrote:Good numbers. So 130 hp crankshaft so is it a good combo of cams for a stock ecu? **COROLLA EE80 - 4AGE 124HP** |
02-19-2009, 06:35 PM
tolisspi Wrote:oldeskewltoy Wrote:what do you mean?tolisspi Wrote:Good numbers. So 130 hp crankshaft I believe it is a good combo for a stock afm ecu... I have no exp with MAP ecu based cars. What do I mean? As temps rise... my cars idle will change. As the seasons pass, I find I have to make minor idle adjustments. As winter moves to spring, the idle screw needs to be opened up(raised idle). As the cool weather approaches after a warm summer, the idle needs to be gradually turned in(lowered idle) If I leave it at winter settings during the summer, the car will idle at about 500 rpm and want to stall. If I leave it set on summer settings, the idle in the winter would go up to about 1200 rpm. A minor adjustment during the seasonal change allows her to run just fine Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
02-20-2009, 09:29 AM
very interesting info!
02-20-2009, 09:36 AM
Indeed :wink:
Toyota Corolla KE30 + Toyota Corolla AE86 |
02-20-2009, 10:57 AM
tolisspi Wrote:very interesting info! That's interesting! Tolis,i think it's time to change your camshafts.. Oχι,δεν το πουλαω... |
02-20-2009, 11:12 AM
You ae bad boy
you want my cams im jocking **COROLLA EE80 - 4AGE 124HP** |
Digital speedometer on stock dashboard | FanIsHere | 0 | 1,356 |
82mm Stock compression Pistons | apardal | 4 | 2,741 |
20v Silvertop stock ignition timing and fueling maps | Lykowsky | 5 | 13,317 |
Most stock-resembling exhaust for the AE86? | DaLanZhu | 4 | 5,550 |
stock injector deadtime for 4age 20v silvertop/blacktop injector | ditn | 1 | 5,817 |
