how much tuning before ecu needed
05-02-2008, 11:41 PM
ok so ive done a search on tuning the 4age,both here and toyota owners club,and i dont feel ive got much useful info as far as the ecu goes
i want to play around with the standard engine in my car while i consider future engine swaps ive got new leads and plugs,cambelt and waterpump changed,apexi filter intake cleaned might get one of those obx exhausts and manifolds(wrapped) as mine is knackered and i dont want to pay 500 pounds for a buddy club back section,prices on exhausts are silly over here!!,decat pipe is ready to go on. alloy alternator and water pump pullies have been ordered,viscous fan is coming off for an electric one,engine has 136km under its belt will the above mods free up much power or do i really have to get cams before it livens up? at what point on the std 4a does the ecu need replacing? ![]() |
05-03-2008, 02:55 AM
koh I think no one can answer that. I have 133 hp on the wheels. So I assume around 150 at the crank and I am now at the point where I need a diffrent ecu.
The standard ECU is pretty good as long as all the standard parts stay intact. (intake etc) With cams you can gain alot. But when you want to go all the way you need to start with the basics. head work and lower block. Than you can do anything Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
05-03-2008, 03:11 AM
The Apexi filter should help. I put on the filter and intake kit, and
noticed that it pulled harder and smoother at higher revs. But I once put on a cheap generic tubular exhaust "header" and found it made no difference. Since then I have changed back to the factory cast iron header, and it works fine. Lightweight pulleys and flywheel don't make any power, but they will improve the response of the engine to the throttle ![]() Cams up to around 260 deg and 8 mm lift will drop in without any other modifications. They give a nice lift in power with only a small loss in idle quality. Depending on the grind, exhaust size etc, you may lose some low rpm performance, while gaining mid and high rpm power. An aftermarket ECU can give you a modest performance increase on even a stock engine. Best results will come after you free up the breathing, raise the compression and feed in some more fuel ![]() When you have full control over fuel and timing, you can tune to take advantage of your mods. Factor in some quad throttles, and you have the makings of a serious fun machine. I'm working towards this right now ![]() Cheers... jondee86 ![]() |
05-03-2008, 10:49 AM
im not sure i want to go as far as itb with this engine,the furthest i want to go is taking the head off to increase compression slightly and change the cams
had more of a read through ecu info on here and it seems the standard one is very good,so it looks like its not worth doing in my application also obx,its a 4 into 1 header,perhaps thats why it doesnt give much gain,perhaps i will just replace everything from cat backwards and wrap the stock header,the dizzy is very close to it ![]() |
05-03-2008, 11:34 AM
interesting thread - had the head done recently, along with 256 cams & cam pulleys. Header is stock, cat stil in and a HKS cat-back exhaust. Stock headgasket.
at first it felt like it actually had less power in high revs, but more torque in the midrange - now after running it in properly on the ring it runs better than before in the high rev's as well. But it should make more power I feel... didn't put it on the rollers yet, though. robokill, what modifications made you end up with 133 at the wheels? |
05-03-2008, 12:41 PM
Yes, I have 255 intake/250 exhaust cams, and the difference from
stock is not huge. On my smallport engine with standard compression it pulls harder from about 3000 rpm all the way to redline, with what feels like a fairly flat torque curve. I'm still playing around with the cam timing, to see what works best, before I put it on the dyno. When I tried the cams at 110/110 lobe centres, they felt no better than stock. Now I have them at 102/114 and I can definitely feel the difference ![]() And the stock ECU is working fine. I have it idling at 800 rpm with 15 deg base ignition timing. Cheers... jondee86 |
05-03-2008, 02:10 PM
how much tuning before ecu needed | |||
05-03-2008, 09:47 PM
thats a great page with a lot of good info cavey,thanks
05-04-2008, 10:09 AM
np, i've read on this board that everybody that stumbles on billzilla's site, will lose a couple of hours just by reading all his info
![]() I know I did ![]() ![]() |
05-04-2008, 07:53 PM
cavey Wrote:np, i've read on this board that everybody that stumbles on billzilla's site, will lose a couple of hours just by reading all his infoLOL ![]() I know from experience you will spend some more time there in the future. ![]() I always think it is a great reference site. Also the url is easy to remember. ![]() 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
Ecu ROM tuning | Alex170984 | 4 | 6,454 |
10-13-2013 08:03 AM Last Post: Apsogos |
All I should know about suspension before any modification | damusto | 20 | 24,349 |
how much boost 4agze | lifebeginsat8000rpm | 5 | 6,971 |
01-22-2013 08:06 PM Last Post: lifebeginsat8000rpm |
Need help (4ac engine tuning) | fullybuiltmiata | 3 | 7,138 |
08-20-2012 09:25 PM Last Post: banpei |
GZE swap or N/A tuning | Okami | 14 | 17,088 |
06-14-2011 10:53 AM Last Post: Okami |
