how to disarm the T-vis?
05-18-2007, 06:18 PM
please no comments wether it has or hasnt any use in this topic.
Let me be the donkey to find out But I dont have a clue wich hose to pull of and close of. I would appriciate it if I can get some clear pictures or a clear how-to :wink: I reject your reality and substitute my own! No more Panda.. Tricolor bastard! If it 'aint broke, fix it 'til it is |
05-18-2007, 07:06 PM
Disconnect either the vacuumline or electric connector and it should stop working.
05-18-2007, 08:19 PM
and where do i find either of those?
05-18-2007, 09:45 PM
05-19-2007, 09:17 AM
Depends if you want them stuck closed or open.
05-19-2007, 10:40 AM
open offcourse
But I've disconnected the T-vis connector now. I do notice some loss on low rpm torque, but now when im driving at 4000/4500 rpm steady and I floor it, the response is much better! Before this, the t-vis needed about a second to open or something like that. Now it just goes when i put my foot down at that rpm range. Now i need a driftday to find out if 3th gear drifting goes easier. Last time when I was in a second gear drift almost in the rpm limiter and i decided to go to third gear, the revs went to just the point that my t-vis closed for a moment. At that point I got in a noticable powerband dip and the engine just dropt dead so ik had to shift back to second. I think that's also all over now, because i dont have that dip anymore. I reject your reality and substitute my own! No more Panda.. Tricolor bastard! If it 'aint broke, fix it 'til it is |
05-19-2007, 12:17 PM
Dwars,
if you're really tinkering with this, get yourself another Tvis plate and take out the butterflies all together, then install that in place of your current Tvis. That might improve things a little as well on the high rpms. Even when stuck open these butterflies still form an obstruction. Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
05-19-2007, 10:13 PM
I still have one of those butterfly-plates in my shed. So if you need one...
05-19-2007, 10:26 PM
how much?
T-VIS/ENGINE | DJexor | 9 | 8,511 |
09-09-2005 07:33 AM Last Post: Ivan141 |
