lack oil pressure - dead engine? Please help
06-21-2005, 12:32 PM
Few days ago I was crusing in my ae86 on a highway.
5th gear, 140kmph, around 5000rpm.
I noticed that my oil pressure gauge was near the low sign. I started to slow down. As I slowed down, the oil pressure was falling lower and lower, until it stayed on 1/4 od the gauge, check engine light goes on.
As I stoped i heard strange mechanical noise from the engine. Also engine would not idle, just dies. It took 30 sec for me to slow down.
So I check the oil level, it's ok, enough coolant, no overheating, but dead engine.
I looked bit in to the radiator, looks like clear coolant, no oil, so headgasket looks OK.
Called the towing truck and towed AE86. I didin't want to drive it.
So, I asume
a) spun bearing on crankshaft
b) oil pump
What should I do/check first?
Can I remove the oil sump from the engine without taking the engine out?
06-21-2005, 04:48 PM
man thats sad to hear.
yess you can take of the sump without rasing the engine.
You can even change bearings - but it´s a hell of a job.
when my first engine went dead is had started to sound a lillte knackering noice from the rod-bearings.
even after i took the bearings out - they seemed "ALMOST" ok.
minimal damage had caused a noice like a bulldozer on asfalt doing som drifting Cool
i would change the bottom end - but only if you can to 100% see that the head has NOT taken any damage - Specially the camshaftbearings.
mine were totally destroyed
BTW - you do not know for how long you had been driving with LOW oilpreassure then ???
Kris Sad .
06-21-2005, 05:53 PM
Zax, its not a problem atall changing the conrod bearings without taking the engine out. You need to remove the gearbox-brackets between engine and gearbox (one on each side of the engine) to get the oilpan down. It took me approx. 1½ hour to get it ready for new bearings.
The crankshaft bearings cannot be changed without pulling the engine out of the bay...
But i would guess, that your oilpump has died and that had caused the lack of oilpressure.
06-22-2005, 08:27 AM
Low oil pressure and knocking noises - my guess would be bearings. But the check engine light and engine dying is a bit weird- is that normal with dead bearings?
02-14-2006, 11:27 AM
Sorry to dig this sad old topic, but to inform everyone: I had 2 spun bearings on big ends.
Hope this information will not be useufull to anybody else.
02-14-2006, 12:06 PM
Hahah, Zax dude, it took you half a year for that huhSmile
Go give the white comet a new engine!
  TUV RHD AE86 Germany (help please) 4dori 9 7,162 07-17-2019 07:42 PM
Last Post: Hachigo83
  Oil leaks - Help Bojack 4 5,688 10-19-2018 01:34 PM
Last Post: Dave W
  Build your own adjustable fuel pressure regulator ;) oldeskewltoy 8 21,333 08-19-2018 12:08 PM
Last Post: AlexKTM
  Carb question please help MIGGZFSU 3 4,772 03-29-2017 03:06 PM
Last Post: MIGGZFSU
  Whining noise HELP PLEASE izanagi 10 12,446 03-26-2015 06:48 PM
Last Post: Komba
