mass air flow sensor mod?
06-17-2008, 09:23 AM
Anyone know where I could fine a step by step guide for this mod?
thanks |
06-17-2008, 05:22 PM
Skeptical Wrote:Anyone know where I could fine a step by step guide for this mod? Kind of a useless mod. No power gains, more gas usage... Why do you want to do this? Andrew |
06-17-2008, 06:07 PM
just heard it was a good mod to do on the car. Since I'm still trying to figure out things on my car I didn't know whether it would be ok to do.
06-17-2008, 06:36 PM
Nah, waste of time & will only lead to the car not running right.
Your time and effort would be better spent getting the car reliable. IE: doing maintenence (sparkplugs/cap/rotor, changing all fluids, ect.) and perhaps replacing all the blown suspension bushings. Andrew |
06-17-2008, 10:44 PM
oh ok, thanks for replying tho. Currently using a fwd distributor cap on my car as well as ngk wires.
another question I have is; how to know if I have a high or low compression motor? Do I have to take it apart to find out? |
07-06-2008, 02:44 AM
So true, unless you design a circuit to modulate the signal correctly.
Fitting Air Con (No PS) to LHD AE86 | pack | 7 | 4,133 |
01-07-2024 11:36 AM Last Post: CCB |
Lambda sensor wiring | sam3007 | 10 | 4,456 |
Air Cleaner Assembly | Hama86 | 7 | 9,327 |
10-29-2018 03:28 AM Last Post: Hama86 |
AE86 4age engine not starts crank ok backfires to air intake | Ryo | 18 | 17,391 |
08-16-2018 01:36 AM Last Post: Bean |
Bluetop AFM with air filter | izanagi | 4 | 7,084 |
04-29-2016 07:29 PM Last Post: oldeskewltoy |
