my bluetop 4a-ge won't start HELP
07-04-2013, 05:57 PM
Got some seriuos problems.
Thing is my hachiroku atm is stored in dry garage, fired up like every week or two.
Everyting was fine to last week, i just came up wanted to take it for a ride, but pretty much my 4 pistons just made a cough and then noting even a one beat.
Up to date checked:
-nice and big spark
-fuel pump is running as a hear it after every single attempt it does build initial pressure in the system.
-new distributor cap plugs and wires (was working on this set)
Engine is fairly stock utillises only fuel pres reg from red top which is if i remember right like 3 bar instead of 2.5 bar
I have no clue, i have checked all connections preety much HELP!!!
we ride together
we die together
07-04-2013, 06:16 PM
Try with another battery Wink
07-04-2013, 06:23 PM
battery is working fine cranking up well
if that would be ecu issue then fuel pump wouldn't work or there would be no spark am i right?
I'm a bit disapointed about the fact because she never let me down up to now.
we ride together
we die together
07-04-2013, 06:41 PM
Does the startermotor work properly?
ハチロク
[Image: AEU86 AE86 - my bluetop 4a-ge won't start HELP]
07-04-2013, 10:00 PM
yea all ancilaries are working fine at least were, finally after work today i have found out that plug for air/fuel mixture regulator was loose just a bit, so it was tricky to see if it connects inside.
plugged in and legend about toyotas reliability is still alive Big Grin
we ride together
we die together
  Refreshed 20v blacktop first start.. Mylesmck 6 1,060 10-07-2024 07:55 AM
  Warm start problem DJexor 5 2,615 03-09-2023 10:15 AM
  Bluetop Engine Rebuild multiple question Goal 150-160hp Hanzo 16 10,240 04-19-2021 10:08 PM
Last Post: Hanzo
  Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP mister86 12 11,835 02-10-2020 06:39 PM
Last Post: Power_uP
  Weak spark, doesn’t start. AlexFourTwenty 4 15,982 12-12-2017 03:35 AM
Last Post: AlexFourTwenty
