need info distributor 4A_C and 4AGE
07-09-2007, 07:35 AM
got a 4AGE head fitted to a 4AC block all done(all 4AGE)PArts
got it drop in my old 4A-C(carb)
this is the new setup 4Age with weber carb ..i need to connect the distributor..
how do i connect this to my old 4AC setup
07-09-2007, 09:35 AM
http://www.rollaclub.com/board/index.php...opic=11302
4AGE ignition depends on 4AGE ECU.
Better use different ignition management (some people even use static ignition advance). IMHO go MjLj (mappable, http://www.picasso.org/) or some distributor with mechanical advance + driving gear from 4AGE one (for example - 4K one). You can use 4-ping HEI igniter to drive the ignition coil - this is simple and cheap setup.
  Toda timing info - with good general 4AG timing info too oldeskewltoy 0 4,342 11-05-2016 01:34 AM
  16v distributor hole plug harkes 8 9,645 10-12-2016 11:13 AM
Last Post: harkes
  Changing distributor when carb 4age izanagi 14 15,812 07-04-2016 03:27 PM
Last Post: Uzelac
  4age 16v 1st and 2nd generation cams and not only difference Apsogos 3 7,699 09-16-2013 08:24 AM
Last Post: Apsogos
  Injector sizes info ZaX 19 36,653 07-17-2013 01:54 AM
Last Post: jondee86
