noise from engine bay
09-28-2008, 03:50 PM
Hi folks,
not been around for a while as I've been a bit too busy at home
I took the cam out yesterday and it seems to have developed a high pitched whistling noise thats cooming from around the injection area.
I believe its a leak on the vacuum side but can't find it.
Anyone any ideas on what to check, how to check it. What can I spray around under there to identify where its a problem
thanks for the help in advance
cheers
Paul
Live life on the red line
09-28-2008, 03:59 PM
put some washing up liquid around the gasket, if it starts bubbling anywhere, you should find the culprit.
Is it idling rough at all?
09-28-2008, 04:04 PM
idling sometimes is a bit arratic... a bit lumpy is the best way to describe it
09-28-2008, 04:16 PM
since you did the cam or before aswell? usually an eratic idle (mild seeking) is a vacuum leak. so do a bit of checking and see what you can find.
09-28-2008, 05:16 PM
sorry for the confusion....need to get my wording right
Cam=car=Twincam ....Not camshaft in this case
Car is as left factory and is untouched apart for the belt being replaced by a local mechanic a year or so ago. Noise wasn't there until recent
I'll have a mess around under the bonnet with the washing up liquid and see what I can find
thanks for your help
09-29-2008, 01:32 AM
If it is a vacuum leak, use a lot of soap, as you will need to watch
the exhaust pipe for bubbles Tongue
For a vacuum leak you should use "engine start" and spray it around
the manifold to see if the idle speed increases.
Cheers... jondee86
09-29-2008, 09:50 AM
Stig Wrote:sorry for the confusion....need to get my wording right
I did wonder why you had just taken out a cam Tongue
Make sure to check all your vacuum pipes for severance, the slightest cut on a pipe can cause problems, especially under acceleration.
Was it lumpy before the noise developed?
10-27-2008, 11:13 PM
Tried the soap last weekend....no respose. Looks like I'll have to try some engine start and see if the revs increase
  TRD Short Shifter Rattle Noise, It's Normal? Mattolo 19 19,205 04-27-2024 10:04 PM
  Clicking noise from glove box chrisae86 4 1,867 09-08-2022 11:36 PM
Last Post: chrisae86
  Detailed LHD engine bay pictures Bean 0 2,929 08-05-2018 04:09 PM
  Noise Insulation for AE86 decryphe 1 3,972 11-03-2016 11:51 AM
  Whining noise HELP PLEASE izanagi 10 11,993 03-26-2015 06:48 PM
Last Post: Komba
