nzae86's AE86 Levin Tarmac rally car build Project 1
04-27-2008, 11:30 AM
awesome build!
how did you paint your cage black with the rest of the car being white! how good do starion 14" wheels look on sprinters ![]() |
04-30-2008, 01:03 PM
mc68 Wrote:awesome build! The cage was painted first in a satin black then wraped in masking while the inside was painted white , it took a bit of time but it was the look that I wanted. Yeah 14" Starion rims suit ae86's well as the have the correct offset and are easy to find over here, but I have now changed to Nissan 240RS rims 15 x 7 with 205 /50 /15 but only have 6 of them at this stage and am having trouble finding 2 more cheers |
05-01-2008, 01:28 PM
god damn, starion wheels are like hens teeth here in perth..
i need a couple of sets ![]() |
05-05-2008, 06:51 AM
I pmed you but wondering if you have the part number for the bilsteins and the trd springs you use??? also im guessing you still use the standard ae86 struts??
05-05-2008, 10:48 AM
matt mead Wrote:I pmed you but wondering if you have the part number for the bilsteins and the trd springs you use??? also im guessing you still use the standard ae86 struts?? Hi there I have my shocks built by Chris at Suspension Tech http://www.stech.co.nz , he has valved these to my requirements for tarmac rallying .he also supplied the front springs and adjustable sleaves for my N2 car as well . And yes I use ae86 struts as I don't think that I could build anything that would work better |
05-05-2008, 10:49 AM
mc68 Wrote:god damn, starion wheels are like hens teeth here in perth..Well you will hate me then as I had 20 and sold them all not that long ago |
05-05-2008, 02:24 PM
nzae86 Wrote:matt mead Wrote:I pmed you but wondering if you have the part number for the bilsteins and the trd springs you use??? also im guessing you still use the standard ae86 struts?? hello, thanks for that..i sen thim an email about the bilsteins can you remember the spring rates of your springs and/or the part numbers?? you would be my hero if you did ![]() cheers matt |
08-09-2011, 10:21 AM
Had a bit of a noise in my engine , I'm not sure if we have found the problem ??
![]() Maybe! Your addiction to motorsport can only be cured by poverty !! |
08-09-2011, 11:44 AM
OMG
![]() I thought that this crankshaft is unbreakable! Fun is not the straight line! |
08-09-2011, 12:27 PM
Isn't this OEM crankshaft ?
(Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams | oldeskewltoy | 5 | 3,150 |
OST-050 - a VERY special build | oldeskewltoy | 49 | 37,242 |
01-05-2019 07:03 PM Last Post: oldeskewltoy |
d3nso's little AE86 N2 build | d3nso | 27 | 35,346 |
11-13-2017 11:42 AM Last Post: mad.matt |
Sum_Fing_Wong's Project Levin | Sum_fing_wong | 37 | 55,070 |
08-23-2016 01:29 PM Last Post: Ivan141 |
nzae86's TRD ae86 N2 Race Car Project 2, | nzae86 | 577 | 1,192,829 |
04-28-2016 11:16 AM Last Post: Super86 |
