nzae86's TRD ae86 N2 Race Car Project 2,
07-29-2010, 03:12 PM
Post: #351
Project D Wrote:I want the same carbon door cards Yummie!
+1
Also if you can't get hold of AE86 winders in black SW11 MR2 ones are identical.
[Image: AEU86 AE86 - nzae86's TRD ae86 N2 Race Car  Project 2,]
RokuSteady : Shakotan - Tsuraichi - Hippari - Onikyan : 神奈川 様式
07-29-2010, 07:29 PM
Post: #352
what a amazing build! i wish i had those skillz Thumbs up! Yummie!
http://bruutt.blogspot.nl/
07-29-2010, 09:08 PM
Post: #353
Hi , thanks for the help on finding black handles , I do have a couple of facelift black interiors in my pile of interior trim but need to sort the rather large pile to find them !!
I still need to make a cover for the fuel system and battery bracket then off to the track. My sign-writer fitted alot of clear stone chip protector to the guards yesterday to stop some of the stone damage from running soft slicks .
Cheers
Your addiction to motorsport can only be cured by poverty !!
07-29-2010, 09:17 PM
Post: #354
Is it possible to know the flow rate of your injectors ? Dumb question
07-29-2010, 09:22 PM
Post: #355
Project D Wrote:Is it possible to know the flow rate of your injectors ? Dumb question
Hi there
The injectors are a Bosch 460cc , I haven't seen the tuning data yet but would imagine from initial set up that they are at about 75-% duty cycle ?.
Hope this is of some help
07-29-2010, 11:12 PM
Post: #356
Yes actualy that exactly what I wanted to know Wink
(I did some calculations and I found something around 400cc @ 3bars/43.5psi and 80% duty cycle)
07-30-2010, 05:47 AM
Post: #357
I have a quick question for you... Back on page 5 you have a pic of a pile of bolts and brackets you had stripped and electroplated. Where abouts did you get this done and what was the approximate cost? I have a similar pile that needs to get sorted out. Cheers.
07-30-2010, 07:15 AM
Post: #358
Quote:I have a quick question for you... Back on page 5 you have a pic of a pile of bolts and brackets you had stripped and electroplated. Where abouts did you get this done and what was the approximate cost? I have a similar pile that needs to get sorted out. Cheers.
I also asked the same question! If you're in Auckland try Rigg Electroplating (http://www.riggelectroplating.co.nz/) on the Shore - they are doing all of the bolts and brackets from the car for $200...
Cheers
(Sorry to spam your thread!)
http://www.super86.co.nz
07-30-2010, 07:50 AM
Post: #359
I got a bunch of stuff done at Rigg also, for about 200 bucks.
They were pretty slack though, make sure you give them a deadline.
edit.
They did a good job though. I guess doing a heap of nuts and bolts and other small parts is not their favourite type of work.
07-30-2010, 08:58 AM
Post: #360
slacker.cam Wrote:I have a quick question for you... Back on page 5 you have a pic of a pile of bolts and brackets you had stripped and electroplated. Where abouts did you get this done and what was the approximate cost? I have a similar pile that needs to get sorted out. Cheers.
Hi there
I had my stuff done by Forlong and Maisey in Hamilton , sent all the bits in as they came off the car , everything came to about $120 . I have had some fittings done by Rigg (special coating) for work and did take a bit of time but good job done .
  nzae86's AE86 Levin Tarmac rally car build Project 1 nzae86 30 57,178 04-30-2013 07:28 AM
Last Post: nzae86
  my celica race car with race beams Celica RA45 14 21,279 09-14-2011 11:50 AM
Last Post: Celica RA45
  AKR's Daily-driver-race-car asian knight rider 5 10,777 11-01-2009 12:25 AM
Last Post: doggy
  My Project car :D Muchomuchacho 5 6,779 06-05-2008 05:15 PM
Last Post: Muchomuchacho
  A.D.D Performance Demo car (AE86 project) cab32 15 18,093 03-24-2008 03:34 PM
Last Post: cab32
User(s) browsing this thread: 12 Guest(s)
