nzae86's TRD ae86 N2 Race Car Project 2,
04-20-2009, 12:20 PM
Post: #121
Well it seems like my painter is a bit busy at the moment , I know I should not have told him to fit it in between his other jobs!! So I have an empty space in my workshop floor while I wait .
I had some spare time in my work day today so the sheet of Lexan that had been sitting for a while turned into a full set of lightweight windows .
[Image: AEU86 AE86 - nzae86's TRD ae86 N2 Race Car  Project 2,]
I am still to sort out how I can make the drivers window wind up and down
Also I sent a pile of bolts and brackets to the electroplaters , so time to sort them out as well .
Wheels are being made and they should be here in about 4 weeks , so maybe this car will go one day!!
04-20-2009, 01:13 PM
Post: #122
i think jealousy is the word im looking for here Tongue
incredible car Smile
Brake with the left hand, steer with the right foot...
04-21-2009, 08:28 AM
Post: #123
http://cgi.ebay.com/ebaymotors/ws/eBayIS...&viewitem=
saw these on ebay. dont know if they will fit or they are legit but you said you were lookin for trd rims.
gl on the build.
04-21-2009, 11:46 AM
Post: #124
chowdig Wrote:http://cgi.ebay.com/ebaymotors/ws/eBayIS...&viewitem=
gl on the build.
Hi thanks for that , I saw those rims the other day, but they have the wrong pcd and are only 8" wide , I want 9" for the rear and 8" for the front but the same style as those .
Cheers
04-26-2009, 05:24 AM
Post: #125
Well another weekend and a little more progress, I decided the rear side windows were going to need the black trim around the inside , so with some careful measuring and a sharp knife , the protective coating was cut back , the lexan sanded with 600 grit and painted black to look original.
I have all the parts painted white back from the painters , front gaurds,bumpers,body kit, and bonnet , these have all come up looking better than new!
So while I'm waiting on the body this week , the gearbox will get it's TRD close ratio kit fitted. Kit number 33030-AE811
This is a old standard box that I will start with and strip it , fit all new bearings and syncro's , as you can see the TRD shaft's are splined , which is great if you break a gear you can replace only the damaged one .
The diff is about to get the same treatment with a new TRD LSD and 5.3 crownwheel and pinion ,brand new axles , etc
So by the end of this week I should have the body back from being painted and ready to fit all the panels .(I thought that was going to happen last week!!!)
04-26-2009, 11:24 AM
Post: #126
I going to have to see this in the flesh when its finished.
04-26-2009, 11:52 AM
Post: #127
Never, ever add up what this has cost! Huh
04-26-2009, 12:14 PM
Post: #128
hachirokuGTV Wrote:Never, ever add up what this has cost! Huh
Ha ! I don't have a calculator with enough numbers on it! Smile
I have a bit of an idea what this is cost but I try not to think about it, it may well be enough to get the world out of recession !!! Banging head
04-29-2009, 07:35 AM
Post: #129
Well the work carries on with this , as I had a problem with the TRD dry sump pan sitting on the steering rack and wanting to keep the motor as low as possible the front crossmember was due for a tune up !
I should have taken some photos before painting it but as you can see now the rack sits lower than the top of the crossmember and still looks original.
The next area to work on while waiting for the body will be the fuel system,tank and diff cooler .
05-10-2009, 07:19 AM
Post: #130
I am still waiting for the paint work to be completed , I called in to my painter yesterday and the body is all painted on the outside (forgot the camera!) and will be finished this week, I hope ! I will have the red and orange details on the body done in vinyl.
This has given me a chance to catch up on some more small details again.
All the parts arrived this week for rebuilding the steering rack with all new parts and fitting up the Quaife quick rack
A few more parts came back from the electroplaters as well , gearbox cross member with a cusco transmission mount
Also I sent the drysump tank in for polishing as it didn't look that good in blue
The fuel pumps and diff pump have been sorted where they work the best , just need to fold up a couple of small brackets and weld into place.
I also removed the foam from inside the tank and fitted the fuel sender and also another an fitting to the top of the tank , as I used the original breather fitting as a return line to keep the aerated fuel away from the outlet the the fuel pump .
Working out of town during the week so that doen't help with progress but does help pay the bills!
  nzae86's AE86 Levin Tarmac rally car build Project 1 nzae86 30 56,130 04-30-2013 07:28 AM
Last Post: nzae86
  my celica race car with race beams Celica RA45 14 20,741 09-14-2011 11:50 AM
Last Post: Celica RA45
  AKR's Daily-driver-race-car asian knight rider 5 10,547 11-01-2009 12:25 AM
Last Post: doggy
  My Project car :D Muchomuchacho 5 6,615 06-05-2008 05:15 PM
Last Post: Muchomuchacho
  A.D.D Performance Demo car (AE86 project) cab32 15 17,661 03-24-2008 03:34 PM
Last Post: cab32
