outer tie rods for ae86,oem or T3
12-06-2013, 10:48 PM
My outer tie rods are broken again and i wonder if i should go oem again or t3 ones?
Its for a track ae86 that is also driven alot on the road to tracks/rallyish events etc
I wonder if there would be much vibration from the t3 ones(which i dont want so i would go for oem in that case)
12-07-2013, 04:26 AM
Hi, dont know why you expect vibrations from them? I´m using them for 2-3 years on track, but also drove from the UK to Germany a few times. Changed the inner tie rod when I put them in and had to change them once since.
Make sure you put the rose joints in a grease filled rubber cover. They will last forever. Wink
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
12-07-2013, 08:58 AM
i have them, good stuff Thumbs up!
drift ae86:308bhp/435nmEDIT:384pk/498nm!!!!>now DEATH)))
12-07-2013, 03:28 PM
Sounds good ill order them then ,i already have the t3 steering knuckles Thumbs up!
thanks for the info
12-07-2013, 03:33 PM
How are they broken ?
Snapped off, bent or worn out ?
12-07-2013, 05:01 PM
worn out,i didnt knew the correct english word.
I usually replace them once a year but they i dont think they are no longer oem sold.(nipparts)
I got different ones this time and i sent them back.
12-07-2013, 09:01 PM
I've had the t3 setup for a few years now with no issues, but my car rarely sees daily use. Every component in the kit is a lot beefier than oem. My only gripe is they chose to use a locknut with a nylon insert instead of a castle nut/cotter pin.
  crank, rods & pistons Alex170984 4 7,009 12-12-2014 05:31 PM
Last Post: Alex170984
  is it possible to get new outer 1/4s for a two door hachi ? adamsaiyad 1 4,466 02-09-2011 10:36 PM
Last Post: adamsaiyad
