power steering on ae86 : suggestions
06-03-2011, 12:36 AM
Keep manual steering, power steering won't get as much angle on an AE86. Get power knuckles, or if you can't source those get T3 knuckles and use the outer position. This should be enough you start rubbing the chassis rails.
What is your caster set to? If it's 3.5 or more, try 3.0 or 2.5.
Andrew
06-03-2011, 12:38 AM
assassin10000 Wrote:Keep manual steering, power steering won't get as much angle on an AE86. Get power knuckles, or if you can't source those get T3 knuckles and use the outer position. This should be enough you start rubbing the chassis rails.
Andrew
Thanks Andrew.. check again my "edited " post.
Thanks Smile
06-03-2011, 12:45 AM
Again... what's your caster/alignment? Lower caster, less than 3.5 for instance will make it easier to turn/steer.
Andrew
06-03-2011, 12:53 AM
assassin10000 Wrote:Again... what's your caster/alignment? Lower caster, less than 3.5 for instance will make it easier to turn/steer.
Andrew
if i remember it was 4.5 or 5 , and 0.7 toe. i think i have paper from wheel aligment in the car. can tell exact numbers in 12 hours or so.
06-03-2011, 01:07 AM
That's really high for an AE86. I'd try 3.5-3.0 to start with if that's the case.
Andrew
06-03-2011, 01:10 AM
I'm with assassin, most likely an alignment problem. Steering feel can change dramatically. Effort is not a problem on mine..same engine(almost), no PS.
06-03-2011, 11:57 AM
To Xerius, when the car is stationary if you watch what is happening to the front of the car when you turn the steering you can see that high caster angles ensure you are actually lifting the front of the car with the steering wheel ! That's always going to make the steering heavy. Your caster arms must be maxed out to get that much angle.
  Power Steering Removal 20valver 2 922 05-19-2024 06:48 PM
Last Post: 20valver
  Power steering clunk Jezza_hr 12 15,281 09-24-2021 01:42 PM
Last Post: pack
  Why Manual Steering Rack ?? Power Steering Removal juantonwan 26 44,370 10-02-2014 06:07 PM
  AE86 non-power steering problem andee17 3 7,421 07-25-2013 06:41 AM
Last Post: jondee86
  Power steering question totta Crolla 3 4,675 02-19-2013 01:52 PM
Last Post: totta Crolla
