power steering yes or no...?
09-28-2008, 09:31 AM
Ozone Wrote:Akina, you need to use a non-PS column with a non-PS rack. FYI: the intermediate steering shaft (removable part that comes out of the steering column - has the splines the u-joint slips onto) from an MKIII supra (87-92) will slip right into the corolla P/S column & connect the manual steering rack to the p/s column. Andrew |
09-28-2008, 09:44 AM
topi Wrote:I have a non PAS levin, with wide wheels and lots of camber. I'm a Yeah... wide tyres are really only a problem when parking, or making similar walking pace manouvers. Even with standard width tyres on a non-power steering car, you soon learn to turn the wheel while the car is moving. Once you have some speed up, the problem disappears The upside (IMHO) is that you get a better feedback from the front wheels without P/S getting in the way. Cheers... jondee86 |
09-30-2008, 08:56 PM
W\ell done)thanx for All
Rising Sun T |
10-01-2008, 12:16 AM
jondee86 Wrote:topi Wrote:I have a non PAS levin, with wide wheels and lots of camber. I'm a Quoted for truth. After driving around for a few days without power steering, I can easily say that the feedback you get is far more noticeable (this is not the first time i've driven an 86 without ps) without it. The downside to it however is you cant steer as quickly, so flicking out the tail end of the car is a little bit more work and a struggle to some. I'm toying with the idea of putting it back on, simply because i'm used to the power steering now and I do a lot of parallel parking and street driving. One thing I did ask in another thread is if it's damaging to the PS rack if it has no fluid in it - e.g does the fluid lubricate anything that could get wear and tear if it's not lubricated? |
10-01-2008, 01:48 AM
for maximum comfort use powersteering
for maximum controll don't, same rules apply for the brake booster 3x ke70, 2x te71, 2x ae86, 1x ke20 and 1x hilux |
Power Steering Removal | 20valver | 2 | 852 |
Power steering clunk | Jezza_hr | 12 | 15,085 |
Why Manual Steering Rack ?? Power Steering Removal | juantonwan | 26 | 43,796 |
AE86 non-power steering problem | andee17 | 3 | 7,328 |
07-25-2013 06:41 AM Last Post: jondee86 |
Power steering question | totta Crolla | 3 | 4,617 |
02-19-2013 01:52 PM Last Post: totta Crolla |
