problem again , about leaking half shaft bearing
03-22-2009, 01:03 AM
Thanks Jondee, the oil seal is new and I tried 2. Now I have applied sealant between the oil seal and housing.But Had no time to test .
Next rally is planned for March 29 ....
And I also applied a trick a friend gave me about the oil seal spring:
Removing the spring , you can open it , as there is a small "screw axis ".
Just find it and unsrcew one side of the spring . Just cut , let's say 5mm to 10mm. Screw it again and put it in place . The lip will be more tight and a better sealing can be obtained .
Done , but not tested .
Just fitted my FC Mazda RX7 calipers , and all must be tested....
REgards
Phil
Filh
Save the RWD cars
  Play between steering column and intermediate shaft after manual rack sonversion DaLanZhu 5 7,279 07-31-2019 11:28 AM
  Steering shaft issue Ryo 15 13,463 11-19-2018 09:52 AM
  Half Shafts Poblem AlexKTM 6 7,101 04-23-2018 04:42 PM
Last Post: MIGGZFSU
  20v mains & big end bearing izanagi 9 10,790 12-26-2016 12:42 PM
Last Post: pack
  Wheel Bearing Temperature Super86 5 6,992 09-29-2014 12:26 AM
Last Post: jondee86
