question about rear axles
05-05-2012, 12:02 PM
The clutch used can make a difference too.
05-05-2012, 12:36 PM
Filh, you know about this solution right?
http://www.weirperformance.com/axlekitsc...erear.html At about 1000€ including shipping its 1/3rd to 1/4th the price of a completely setup Atlas axle and uses OEM parts. Probably also available direct from: http://www.coneindustries.com/partsgallery.php# There used to be a company making a fully floating Toyota rear axle, Dwarf Car Products, but dunno what happened to them. A wheel to steer the front of the car A pedal to steer the rear |
05-05-2012, 11:58 PM
Hello,
to Totta Crolla I think the same . I use a clutch plate with 4 pads(Cross) and no springs. I may be to rigid , and not absorbing much impact. But I remember that I broke axles with a stock Sachs clutch plate. to NoHachi : I knew Weir solution. Very good for the axles dia(30mm) , but you have to use a spool replacing LSD. It gives a 100% "LSD" . Not very easy to compete with that . You have to be full time at 90° in corners ![]() ![]() ![]() And if you failin that way of driving, you look like a FWD Rolla . ![]() ![]() ![]() Don't like FWD at all....(speaking about competition). Weir has a solution with 28mm axles and a modified TRD LSD , but it's much expensive, and I 'm not assured it's much more reliable than the 25mm ones. I can assume to change axles sometimes, but the prices asked are much too high now. These parts are , at least, 25years old , and metal is often tired (due to sport use) By the way , thanks for the interesting links . Infortunately, buying overseas (which I often do) involve custom taxes , and they are absolutly crazy here in Belgium.I use to pay 100% taxes. I recently paid 54€ customs taxes for a warranty return from Japan ,and I didn't pay anything for part and shipping !!!!! Phil Filh Save the RWD cars |
05-06-2012, 01:01 AM
Torsion stiffness (traagheidsmoment) goes up with a power of 4 with the diameter of a circle.
So a 25mm axle has a surface moment(?) of pi*(25*2)^4 /4 = 4.9e6 And 28mm axle has a surface moment of pi*(28*2)^4/4 = 7.7 e6 So you need about 1.5 times the torque to snap the 28mm axle. 50% strength increase isn't as bad as it seems. A spool LSD isn't as bad as it seems. It just takes a skilled hand to get it into a corner. After that, it isn't very different from a normal LSD. In Holland we pay 30% duty+taxes. So if you need any parts it might be worth sending them through some of our dutch members. A wheel to steer the front of the car A pedal to steer the rear |
05-14-2012, 02:14 PM
NoHachi
30% duty+taxes That’s too much man , any other way to get parts from Germany or Belgium for example |
07-01-2014, 02:25 PM
damn taxes we pay a lot
