small port in which model
08-25-2007, 02:18 PM
Dear all,
I was just wondering in which models and which years the small port is used ?
If I look for parts etc I always look at the AE 92 but it seems this car also came with 4 af and 4 afe ?
The corolla GTi ( 1987 - 1993 )uses the small port but others ?
If I need a head gasket for instance etc I do not think there are any differences between 4age´s ? Confused
http://www.heerlijklimburg.nl
08-25-2007, 02:39 PM
jos 4 age Wrote:Dear all,
AFAIK only AE92 GTi ... in Europe.
Toyota scrap yard car park = AE92GTi - AE82GT - KE30 - KP62
08-25-2007, 02:51 PM
I have a 1990 AE92 GTi , there was a small port 4A-GE (nowadays it is in my AE86).
I also have a three AE92 GTi's (1988-89) and all those have a big port 4A-GE.
Original small port head gasket P/N is 11115-16070, if needed.
"Tämmösellä modernilla autolla, niin mun mielestä, ei tämmöstä kisaa voi ajaa. Tää käy kunnon päälle eikä riitä aivot tähän touhuun!"
""With a modern car like this, in my opinion, a competition like this can't be driven. It's too physical and your brains can't cope with this stuff"
-Henri Toivonen 2.5.1986-
http://www.youtube.com/watch?v=OwgB4Xs4LVQ
08-25-2007, 06:37 PM
thanks !
is the head gasket from the small port different from the big port than ?
I think it is.
should I use original one ? It is always difficu´lt to explain in the shop that you need a head gasket for a 4 age small port as mostly they can find 4 age but there are several 4 age´s of course...
08-26-2007, 10:19 AM
Any 4A gasket (maybe any A-gasket) can be used. There is a difference but 4AGE gaskets are equal. Diference is larger water passages etc.
08-26-2007, 12:54 PM
I read somewhere that the 7AFE head gasket is thinner, and good for the 4AGE. I bought one and it is thinner but the water passages are absolutely not at their right place. With some dremel and diamond cutters I made these holes, but by this time I didn't try it. Hope it will work, but doesn't worth the work to do it.
The smallport and bigport 4AGE's have the same headgasket. By part number also the same. 11115-16070 as I remember.
jamiemirror Wrote:Any 4A gasket (maybe any A-gasket) can be used. There is a difference but 4AGE gaskets are equal. Diference is larger water passages etc.
08-26-2007, 01:46 PM
thank you for the info ! i can just order a 4 age head gasket now Thumbs up!
  20v BT - which oil pump? Mylesmck 4 3,111 06-21-2022 04:51 PM
Last Post: pack
  Early tvis red top from e9 gti small or bigport? Ryo 3 7,809 04-20-2018 09:14 AM
  Rim width. Which is best.... Dino86 5 7,052 01-07-2017 03:09 PM
Last Post: Dino86
  Small Port Swap Alex170984 1 4,374 11-21-2016 01:46 PM
Last Post: Alex170984
  Small Port 10.3 Pistons Alex170984 1 4,520 10-25-2016 09:18 PM
